'98 V70 Serpentine Belt Tensioner Rattle
Has thanked: 311 times
Been thanked: 817 times
4 or 5 bad spring tensioners does not sound right at all. So far I've replaced only the bearing part of the serp tensioners on some of my p80 cars, and non of them are noisy. So I doubt you have four bad ones but of course it is possible.
Maybe we should torque wrench measure a bunch of them, noisy and not! But what kind of adapter to fit in there? Quarters (lol)???? Measure the ft-lbs it first moves without clicking, or just measure the tension after movement if you have an old school torque wrench with gauge on it, though I suspect those tend to be less accurate. I may have to break that wrench back out.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
3/4" torque wrench would be ideal, though I personally do not possess one.
1/2 to 3/4 adapters are cheap and easy to get, but I don't think 3/4 works does it?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
erikv11 wrote: 24 Sep 2020, 19:52 1/2 to 3/4 adapters are cheap and easy to get, but I don't think 3/4 works does it?
I ended up replacing the tensioner on this car with a new INA one, and still thought it had a little too much movement.
You could use a 1/2" torque wrench with a 1/2" to 3/4" adapter, but the tensioner would need to be out of the car and in a vise or something. No clearance in the car to do it that way.
It does, but I've noticed on Meyle tensioners it's a little tight and you may need to file it out a little bit. Fits just fine on INA tensioners.
Cookeh
Post by Cookeh »
Its a 19mm square hole in the tensioner, if I remember correctly, so you wont get much closer than 3/4". As above, with an adaptor you cant get the clearance.
Another potential option might be a crows foot spanner on top of whatever adapter one uses to fill the 19mm hole. Of course any play in that adaptor will throw the results off. Clearance may again prove tricky though, and I also lack any crowd foot spanners.
bmdubya1198
What I always do to release -'98 tensioners is use my 1/2" to 3/4" adapter with a 19mm wrench on the 3/4" portion. The key is to only seat it far enough into the tensioner to engage it, and leave space to grab onto it with the wrench.
A 19mm crowfoot could do the job of checking torque if clearance allows.
Been thanked: 4068 times
bmdubya1198 wrote: 25 Sep 2020, 08:43 What I always do to release -'98 tensioners is use my 1/2" to 3/4" adapter with a 19mm wrench on the 3/4" portion. The key is to only seat it far enough into the tensioner to engage it, and leave space to grab onto it with the wrench.
You took a grEat picture of this for clarity Earlier.
A 5 cent per use Royalty Is payable to Bdub or you can donate directly to the “Save the Miatas Fund”
bmdubya1198
abscate wrote: 25 Sep 2020, 11:19
A 5 cent per use Royalty Is payable to Bdub or you can donate directly to the “Save the Miatas Fund”**
I remember posting about it, just not what thread it's in. I think it was specifically about a tool for that.
**No tax deductions on donations.
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
I use a 3/4" square galvanized pipe plug procured at Home Depot, etc. The thread diameter is probably 1". I grab the threads with a vise grip pliers. Insert the square end into the tensioner,rotate to release tension. Use an Allen key or other small gauge rod to lock the tensioner in the released position.
34 inch pipe plug.jpg (7.15 KiB) Viewed 1093 times
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
:D
