Looking at 98 V70 GLT turbo wagon....
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Okay, before ANYTHING else, check when the timing belt was last changed. Absolutely critical . Then your hoses, PCV, etc...descending order of throwing away your money then the car if they fail. Spend time browsing the wonders of MVS, ask lots of questions, subscribe to Robert DIY youtube or Patreon, it will save you time and money, familiarizing yourself with your car, kinda like Babel for P80s! (the language software, not the Old Testament one!!)
Current Volvos:
Has thanked: 311 times
Been thanked: 817 times
Speaking of junkyard, I'd pick up a cluster from a V70XC or etc that has the trip computer activated, just find any 98 with an info switch. Yes the mileage won't match, but so what ...
Has thanked: 1609 times
Been thanked: 4065 times
erikv11 wrote: 17 Sep 2020, 09:29 The transmissions are very hardy, it probably just needs a fluid change as mentioned. I agree with others that a 98 FWD is the best year/model combination. And the LPT is fun to drive.
The 98 is do close the the coveted 100% Rating , only one model year does better..
After 98 it's 07, then a distant pack of other years in third place.
Sufbug
Year and Model: 1998 V70
Has thanked: 2 times
Post by Sufbug »
Ok cool! Thanks.
Gonna do some work tomorrow with my mechanic.
The TRACS system....do I care about the light? Doesn't bother me so I won't fix it.
The speedo sometimes works and sometimes doesn't.
New trans speedo sensor? Or just take it out and clean it?
She is running ok! Always starts. Lol.
Tomorrow is
E Brake fix
cv boot pass outer
Balance rotate tires
Oil lube hood latches (driver side won't open unless you keep lever pulled and second person opens good)
Mann oil filter magnet on drain plug
Drain and replace one quart tx fluid. Magnet on drain plug
General look over. And start maint schedule.
I thought I could post pics just from uploading from my phone but that's not working anymore
Help?
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
FLXC90
Post by FLXC90 »
speedo gets signal from ABS control, flaky speedo and TRACS light equals need an ABS module. See midwest ABS link.
search forum for hood bumper adjustments.
Current Volvos:
Sufbug
Post by Sufbug »
Hey hey!
Time to buy a pass side axle, the cv joint broke, don't ask, but the bearing race broke while trying to dissamble the cv joint to get the new boot on.
So, calling fcp to get an axle overnighted. Or, anyone have any thought?
Al
Sufbug
Post by Sufbug »
Axle installed. Rear brakes and eBrake fixed and installed.
Have bad smoke in the cabin, can't see it, but smelling it makes me dizzy. And it really doesn't smell.
Gonna get some exhaust gaskets, and start from the head and work my way tailward....
Fixing this is a priority now. Exhaust system looks stock, and had her on the lift, and couldnt see anything apparent from the midsection of the vehicle back.
Crazy thing, lowering windows and closing outside vent air doesn't help.
Grrrrrrrrr. Any ideas?
So it is definitely exhaust? People have described mist from the vents when the heater core blows.
Oh and a very common place for these to leak exhaust is the joints for the cat, either the front or back joint. I think I have repaired all of mine now, Well, had them repaired - muffler shop.
