This proves again - what you don't know is not as bad as what you THINK you know, but is just WRONG.
Extra points for going back to it until fixed.
1998 V70 NA M56 Crank (compression, spark, fuel ok) No-start - [incorrect install of distributor drive plate ] Topic is solved
- Has thanked: 987 times
- Been thanked: 1078 times
- Has thanked: 2209 times
Like Rocket99 with his challenge with coil packs, what volvolugnut says I am a +1 to what he says. Sometimes walking away from an issue helps to re-think and issue and then going back to basics helps. Congrats on getting it figured out! Neil.
- Has thanked: 1611 times
- Been thanked: 4072 times
You were totally on point with thisFLXC90 wrote: 17 Aug 2020, 17:12 Ether - I did not get running on ether, I did get an intake manifold backfire which blew off snorkel. was it just swamped with ether, or does this indicate firing with the intake valve open?
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
2020 is finally turning around! Nice work
07 V50 T5 AWD M66 ~146k miles
Triple award of the Volvo horns to Mr Lugnutvolvolugnut wrote: 17 Aug 2020, 17:36 You have spark at the plugs, BUT do you have spark at the proper time in the cycle? This has a distributor, right? Did you remove the distributor doing work? Try using an old timing light to check proper spark timing. Distributors can be tricky to get proper spark timing.
THANKS! to absacate.
(thanks button not shown)
This has become a thankless Forum
Replaced the heater bulkhead so that miss Vermont 2020 has heat
Deep flush of cooling system
Bit toning up ancillaries.
Took pEarl out for a hot 60 mph run. Throttle body lever fell off on lift. Fixed with a spare throttle body lever retainer, which can be used to hold her in a pony tail
villagepc
- Year and Model: 98 V70m | Stage III
- Has thanked: 3 times
- Been thanked: 2 times
Glad ya got it running!
____________________________________________
1998 V70 T5M R Clone | IPD / ARD Stage 3
2008 S80 3.2 - not too shabby
1991 740 Turbo - 2.5" lift, 100% madness
We got the Duchess of a Earl back home safe and sound. We had a wonky idle which cleared when we unplugged the Idle air control valve so that probably needs cleaning. Thread bumped.
Here she is, back with her family!
- 17 Replies
- 2725 Views
Last post by Dingo957
- 26 Replies
- 4418 Views
Last post by momentumbob
- 1138 Views
Last post by nmotzing
- 28 Replies
- 5781 Views
- 518 Views
Last post by oragex
