The Resurrection/Insurrection of GrunHilde - 1998 V70 NA M56 421 Green
Has thanked: 1609 times
Been thanked: 4065 times
Well , we saved this one from a Vermont Field, and i will come to a decision fork in the road on whether this is savable as a driver, or has to be parted/scrapped. It has a bad fender on the driver rear side, and I unfortunately don't have that donor metal anymore.
Not to worry.
First pass, I thought it was goner- heavy rust everywhere on stuff, and it blew a lot of fluids on the engine evaluation (see MAINTENANCE THREAD for that)
....but....
I still have my parts 1998 Clarke in the driveway.
Here is the ugly list at moment
PS rack lines - heavily rusted. Have good used from Clarke
Brakes all the way around - some calipers spoken for, but I can use rebuilts to get going. Turn rotors and drums I don't mind buying parts that can be used on the fleet of my 1999s (total 5 in my family) for this car as I know they will get used eventually
Two front struts and springs - can use Clarkes as test bed to get rolling
Rubber is good.
Electrics work
Car starts and runs well. Absolutely no frigging codes. Even the SAS cycles and runs correctly
AC is dead but that can wait until summer. Can sell good used AC drier to Neil - see pictures
Im not trying to pretend this is an economical save, but Labor looks like
PS - 10 hours
Brakes 4 hours
Struts 2 hours
16 hours at $25 per is $400
Looks like I can get a runner for < $1000 in a cool configuration?
Front struts nasty, steering hard lines dumped oil
Rear not as bad,
Anyone need a used fuel filter?
Ac drier probably isn’t too dry..
Rack doctors in SC has rebuilt rack for $260
https://shop.rackdoctor.net/70-SERIES_c416.htm
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
That is some nasty rusted parts.
Goalis to get another year or two from the car before it’s a donor,
Has thanked: 2199 times
Been thanked: 1851 times
IF you can get this running and safe to drive for $1000 I will be truly impressed! $1000 for 2 years running is cheap running indeed. We may have to christen you an honorary Scot!
Did you ever get the AWD fuel system back up and running? Might even be an easier job than this one!
Good Luck.
The S70 AWD Evangelina needs to go up on a lift and have the rear carrier bolts torched off with oxy acetylene. I’ve hit them with propane 5x and haven’t moved them yet
I’ve got the engine sorted out , if I can get the fuel leak and rear carrier done that will be a nice car
Fuel leak found, don’t quite understand what goes where here though....
Ah, wrong one.
Here’s mine
