I finally got the rear wheels up in the air after a few weeks of rear brake grinding!!! The problem I am having is that I cannot figure out the right size socket/wrench to use to remove the caliper bolts. A 13mm sort of grabs but then slips. A 12mm is too small. A 1/2 inch wrench grabs better than the 13mm socket but then slips. Now the corners are starting to flatten out. I have even applied heat to the bolt and caliper, but the bolt does not want to budge. One rear passenger side bolt is almost rounded, the driver's side is starting to get there! I was able to remove the outer pad on each side but the inner pad seems to be wedded to the caliper!
Any ideas/clues on what I could try next?
Rear caliper bolt size
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 15 times
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
If the calipers are being replaced, try multiple heat cycles. You might melt seals doing this but if it needs to come off I’m guessing it’s seized anyway
60 seconds propane, then 5 minutes cool. Repeat at least 3x
Go around and heat up all four bolts. You finish bolt four just in time to come back to bolt 1
After last cool, hit with PBBlaster or equivalent.
Try a six point socket or one of the grabber sockets from Lowes if it starts slipping
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
6 point sockets are the way to go. Sometimes you can hammer a 12 point socket of a slightly smaller size but you sacrifice the socket.
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Die grinder is the right size wrench.
You have to drill a caliper bolt out, unfortunately
Just taking the head off won’t help.
New bolts and aluminum, or , even better, Nickel anti seize is important on caliper work in the Northeast
5rivers
Yes, indeed! North County weather really does a number on bolts!!
This will be the first time I have tackled these bolts since I got the car, now just over 2 years ago. And believe it or not, the PO took the V70 for maintenance and repair to a reputable Volvo indie garage in Central NY!
5rivers
850oldschool
I ground the head off one back in April. The heat and vibration helped the penetrating oil do it’s job and the stub came out with a vise grip. I used the Harbor Freight electric die grinder, which is like a giant monster Dremel and uses 1/4” shank bits. The pneumatic ones are cheaper but you need a big air compressor.
Why the heck is it always the one on the passenger side? And yes, anti seize on every bolt you install!
- mkc1
- Year and Model: 850 GLT 1997
- Has thanked: 27 times
- Been thanked: 10 times
Grip Tite Sockets and a long pipe worked well for me.
"Learning mechanics is easier than learning male psychology. You can figure out an engine; you can never figure out a man." -- Pepa Marcos, Mujeres al borde de un ataque de nervios [paraphrased]
1997 850 GLT "Volvo"
1997 850 AWD "Junior" (for parts, sadly)
K...heat it up for 60 seconds with propane, then 100 raps with a small hammer. Light Taps likes small woodpecker. Repeat every day for a few days
- 805 Views
- 3242 Views
Last post by XC70DIY
- 15 Replies
- 6497 Views
Last post by wizechatmgr
- 12 Replies
- 3741 Views
Last post by JimBee
- 656 Views
Last post by E Showell
