We're back... on a new server. You can post normally. I'll be working on bugs this evening, so you may encounter abnormal forum behavior. Apologies for the inconvenience!
1998 v70 AWD dome light problem, locks problem Help needed
- Year and Model: 1998 v70awd
I am unable to find a list of component numbers [ ie 2/75 or 7/39 ] with actual name of component . 1998 V70AWD
- Has thanked: 123 times
- Been thanked: 174 times
Re: Help needed
Are these component numbers from an electrical schematic? They sound like they are.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 15 times
- Been thanked: 42 times
Re: Help needed
That's how those read to me also, pin and connector ids from schematic. What are you troubleshooting ( in mechanical terms)
Current Volvos:
Re: Help needed
Yes, electrical components . Have 3 issues , interior [ dome light ] does not shut off when doors are closed . Must switch off at dome light .
power door locks do not work with remote . Battery goes dead if left connected for several days .
Battery works fine in my S70 , so not the battery .
I am retired from my VOLVO shop now 12 years, so not a lot of experience with P80 electrical issues .
Re: Help needed
Dome light assembly works fine in my S70 . Have several proper remotes but none work .
Might add, I have the AUTODIAGNOS MULTITESTER PRO which is what we used at the VOLVO dealership .
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 440 times
- Been thanked: 1333 times
Re: Help needed
I dont think the component numbers are preserved across model years, but 2/76 is the lock controller and 3/79 is the antenna ring in 1999. The component family 2/xxx will be preserved.
If you are having trouble with the courtesy lights coming on, there is a painful thread on that in this forum with 2/76 part number in the title.
No children should be in the room while it is being read.
Link To Volvo Glossary
Re: Help needed
Thanks ! Could the dome light issue and the door locks be connected ? I see several microswitches in door latch . Surely one tells the dome light that the door is closed ?
Re: Help needed
Everything sends signals to the lock controller, which then grounds the lights through a power transistor
It’s a nasty complex system
Re: Help needed
Thanks, tried 2/76 thread search , but it was not found . How do I search thread for 2/76 ?
Re: 1998 v70 AWD dome light problem, locks problem Help needed
This is for a 1999 so the system is different, but gives an idea of the complexity
viewtopic.php?p=498565#p498565
- 31 Replies
- 1791 Views
Last post by ka0ren
- 393 Views
- 142 Views
Last post by purplebeauty
