does the temp gauge in the dash never move ?
pretty sure it takes longer than a minute to start moving.
if it never moves I'd check the fuse first, then the harness.
Only Drained 90oz Of Coolant Topic is solved
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
No, the gauge never moves.
Starting and letting the car run for a few seconds and turning off starts the fan to continue to run and stop latter.
All the lights in the instrument panel works, including the Check Engine light.
The temp gauge does not have it's own fuse to check, or does it?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
its all pointing back to the temp sensor you replaced, did you check voltage at the plug?
it should drop as engine warms up. see if you can backprobe the plug.
Oka
Yesterday, (9/26/20) I posted the voltage from the new temp sensor. Was that what you mean? I did not start our run the engine before taking the voltage.jonesg wrote: 27 Sep 2020, 20:26 its all pointing back to the temp sensor you replaced, did you check voltage at the plug?
What is "backprobe" and how is that done?
Oka
If the thermostat is not opening, shouldn't that (the large air pocket) in the upper hose cause the car to overheat? The whole upper hose seem to be empty.
Seems I have two issues, with new thermostat and CTS:
1. No coolant in the upper hose.
2. Temperature gauge smack down, does not move.
Did you use an OEM thermostat and sensor?
Aftermarkets have a high Failure rate Out of box (OBQ in QC-speak)
Oka
Both were AutoZone brands.abscate wrote: 28 Sep 2020, 04:40 Did you use an OEM thermostat and sensor?
Please what is "(OBQ in QC-speak)"?
Out of box quality, or , in the vernacular, sh****ty parts
- jonesg
You need to read the volts as the engine warms up to see the sensor changing resistance.Oka wrote: 27 Sep 2020, 22:42Yesterday, (9/26/20) I posted the voltage from the new temp sensor. Was that what you mean? I did not start our run the engine before taking the voltage.jonesg wrote: 27 Sep 2020, 20:26 its all pointing back to the temp sensor you replaced, did you check voltage at the plug?
Sounds like you just read the feed voltage.
they sell probes or you can make them from paper clips and insulation tape to prevent them touching.
- 2220 Views
Last post by alschnertz
- 2535 Views
Last post by contented
- 1151 Views
Last post by BEJinFbk
- 1252 Views
Last post by oragex
- 37 Replies
- 10335 Views
