Well, this explains alot. Is this fixiable? Or did I just F*** myself??!!
wbrenegade420
Year and Model: 2006 s60r
Post by wbrenegade420 »
oh my the HORROR!! Please tell me that it's ok and thats it's just merely a flesh wound
I tried repairing with JBWeld, but didn't hold well when tapping. Can I fill it with something? What fills aluminum?
water pump mating surface(2)
water pump mating surface(1)
(JB Weld repair)
Tried JB Weld repair, didn't hold
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Is this the water pump facing?
wbrenegade420
volvolugnut wrote: 28 Sep 2020, 18:24 Is this the water pump facing?
Yes :cry:
Been thanked: 4065 times
What Went wrong with the JB weld repair?
That’s the only shot here.
wbrenegade420
abscate wrote: 28 Sep 2020, 18:39 What Went wrong with the JB weld repair?
I don't think i mixed it well enough or let it sit long enough. I'm looking into aluminum rod brazing. Thoughts on that?
Or what about filling the hole, sanding it flush, and just hoping that the other 6 bolts will seal it enough?
I think there is an aluminum filled JB Weld product. Follow all the instructions including cure time before drill and tapping. This should (?) work. Use about half bolt torque when you get to that step.
Been thanked: 504 times
Post by cn90 »
LOL, How the heck a hole like that happened? Inquiring mind wants to know...
Google "BMW thermostat sealing surface pitted" and see what you get.
Many BMws suffer from pitted surface (probably from bad ground cables) causing pitting.
I think people fix it using a combo of JB Weld + RTV etc.
wbrenegade420
volvolugnut wrote: 28 Sep 2020, 18:52 I think there is an aluminum filled JB Weld product. Follow all the instructions including cure time before drill and tapping. This should (?) work. Use about half bolt torque when you get to that step.
Well, I'll give it a shot. Going to hardware store now. I'll report back.
wbrenegade420
cn90 wrote: 28 Sep 2020, 19:01 LOL, How the heck a hole like that happened? Inquiring mind wants to know...
Not sure. I'm assuming a sh**ty tap job. And i'll be sure to check that out. Much appreciated!
Post by cn90 »
Since this is a potential problem, I suggest that you use ONLY Aisin + Volvo green gasket and nothing else.
You want to use what is known to be the best, this way, if it leaks later, you know it is not the WP or the gasket.
