BCM 0052 and 0050 codes
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Has anyone had these codes ? I did a search but nothing clear other than 'internal permanent fault'. The CEM also has a 1A5F code that won't clear. Interestingly, there is no warning light or message. The ABS works fine on all wheels - tested during winter on ice. I can also hear the ABS pump humming when braking. Car is FWD 2003 STC
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Is correct BCM installed on the car?
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Two things common to both BCM DTCs are electrical distortion scrambling the data and defective control module. Pull the BCM connector and clean it. Check wiring for shorts and opens.
CEM-1A5F is CEM to BCM communication. This could be dirty connectors or wiring also.
Most likely it is an issue on the CAN high speed network not the electronics.
Active
Past
oragex
Post by oragex »
I haven't replaced the BCM but don't know its history from previous owner. Car was bought with 100k miles
Will look closely to the wiring and connectors
yagger
Post by yagger »
In this case will be cool if you show me couple screenshots:
Vin, detailed info about car and tab Network, click on BCM on the image and show me SW numbers also.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
VIDA says my driver power seat has a communication fault (memory wont work) but the seat works fine, i use the memory function all the time. I wouldnt worry too much about it.
2001 XC70 factory M58
2002 XC70 auto (parts car)
oragex
Post by oragex »
I took a picture of the sticker
VIN YV1RS61TX32272264
yagger
Post by yagger »
What about VIDAs tab Network?
oragex
Post by oragex »
I don't have Vida. I use a regular scanner
yagger
Post by yagger »
Can you see BCM software numbers use it?
