1998 v70 NA Grunhilde M56 517772 421 green
Forum rules
Been thanked: 4071 times
Build date 6/1998. Very late 1998 model...woo hoo..that probably means mechanical tensioner
Engine B5254S serial 1412483
Car recovered from field in VT. Not run in 2 years
180,000 miles SEP 2020
To be evaluated for recovery or parts.
Body damage to left rear fender and wheel arch from rust.
Towed home, installed battery.
Engine starts and runs. No codes.
Idled for 30 minutes, changed oil to Penzoil Dino to remove water
No crank condition, battery drain?
Alternator light came on
Dumped PS fluid
Fuel filter area bad gas leak
Oil seep at cams.
Brakes crusty
Steering extremely heavy, not just lack of PS. Frozen rack?
Black Betty 592497 VIN
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
abscate wrote: 25 Sep 2020, 04:20 Steering extremely heavy, not just lack of PS. Frozen rack?
Steering Rack seal Kits run ~$50.00. Overhaul and have like new ?
Active
Past
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I just have this feeling that the wrong vehicle is towing the wrong vehicle... =)
RickHaleParker wrote: 25 Sep 2020, 20:10
Thanks Rick. The rack on this one is awful but I have a TRW on the other car which leaks.
Rebuild $50
Rack doctors $250 with lifetime
Replaced fuel filter
Replaced rollover valve fuel line with aftermarket
Timing belt, idler, tensioner, water pump replaced
Alternator brushes replaced
Both steering knuckles, lower control arms, struts , sway bar links replaced with used parts
Heater core bypassed, core is leaking
Cleaned up and installed front brakes. Good pads on front , almost new
Pushed 250 ml fluid through each caliper
Driver side caliper pins aftermarket and heavily corroded, cleaned and greased
Need 10 mm rotor holds
Final torque front suspension
Front axle 36 mm nuts
Alternator and bracket reinstall
Heater core reinstall
Reinstalled timing belt cover, serp belt , alternator, ps pump
Used reinstall trick to replace serp belt.
Removed tensioner, 2 M8 bolts , tensioned and pinned with 3.5mm Allen key in vice
Reinstalled and threaded belt.
Pulled pin
Alternator replaced
Fuel leak resolved
New serp belt and better used tensioner. Serp belt brutally tight, ran all accessories without tensioner. Installed tensioner. Had to bolt bottom first, then top.
Heater core replaced, tested for leaks. ALl good, great heat.
Radio code 5415
Checked front end torques
Grunhilde is rolling again!!!
