The Resurrection/Insurrection of GrunHilde - 1998 V70 NA M56 421 Green
Been thanked: 4065 times
New fuel filter and replaced roll over fuel line
$20 parts
$25 labor
Removed front struts.
Right side upper Strut bolt snapped off inside strut. Ugly.
One hour
No parts used
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
That’s some of the rustiest rust I’ve ever seen.
I’ve been contacted by the Museum of Modern Art
Even the rust has rust. Amazing.
I got lucky with those sway bar links. Wire brushed them, sprayed with PBB, the put three pumps pressure up on the link with the floor jack. They then zipped off with the Bosch hand impact and 15mm hex?
The pressure up acts as a counter hold so you don’t have to fuss with the Torx. Wisechatmgr and Indeveloped this technique , the Jack Counter Hold MVS (tm) last year
Hardware matrix for Front Sturt suspension, FWD
Application Flange Screw Flange Nut Qty
Ball Joint 988185 987891 2 each
LCA 982 847 985870 4 each
Strut 982845 985870 4 each
Link 985930 4 each
Very late 1998 build so sure to have Mechanical timing belt
Maybe its in good shape??
#Optimist
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
abscate wrote: 02 Oct 2020, 04:17 I’ve been contacted by the Museum of Modern Art
The Titanic looks a lot like that.....
Just spent $100 for nuts and bolts for front end. Have to hide this post or else my Scottish friend will be asking me for the used ones.
The big button for me to push will be the steering rack. Would love to find a used one for $100 or so, but labor to get out is grueling.
I thnk thats the last thing I have to spend money on here. I just got a karmic load of about 80% of the spare parts that are marginal, and now I can replace on the cheap.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
I think its about time we constructed a nut and bolt spreadsheet detailing the thread pitch, grade, and full dimensions of every bolt in these cars in order to avoid paying $100 for $1s worth of steel.
abscate wrote: 02 Oct 2020, 10:55 Very late 1998 build so sure to have Mechanical timing belt
#Optimist
Woo hoo! Mechanical tensioner but it is ugly and very loose. Changed st 77k maybe, now 180k
Has thanked: 2200 times
Been thanked: 1852 times
Wow, that poor car did sit for a long time. Amazing how much rust there is on even the pulleys and mech. tensioner.
What are you going to do with all the rusty bolts..................? :lol: :lol:
Getting a good steering rack is a challenge. Pity you don't live closer. I have a stashed one in the 'just-in-case' pile in the storage facility. Shipping is the killer again. Do Erie have one and how much do they charge?
