FDPP #2
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
FCPEuro shows part VOL-30683516 for:
S60 from 2001 to 2006, automatic, up to chassis number 599999.
S80 from 2000 to 2006.
V70 from 2001 to 2006, up to chassis 616999.
XC70 from 2001 to 2006, up to chassis 253999.
gnalan
Post by gnalan »
yagger wrote: 01 Oct 2020, 17:29 If so, check power on the fuse #8 under hood.
With the key turned off I have 0 volts at fuse 8. With the key in position 2 I have the same voltage at fuse 8 that I do from the positive lug at the fuse box to ground.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
gnalan wrote: 01 Oct 2020, 17:42 With the key turned off I have 0 volts at fuse 8. With the key in position 2 I have the same voltage at fuse 8 that I do from the positive lug at the fuse box to ground.
0 volts on both sides of fuse?
gnalan
Post by gnalan »
Yes, with the key off I have 0 volts on both sides of the fuse.
yagger
Post by yagger »
But what voltage on it if Position II?
gnalan
Post by gnalan »
Full battery voltage with key in position 2.
Been thanked: 504 times
Post by cn90 »
At this stage you have nothing to lose by getting a good gas pedal from either local junk yard or ebay.
Is there a junk yard near you?
gnalan
Post by gnalan »
Nothing close with anything for Volvo's, unfortunately.
gnalan
Post by gnalan »
Had this message this morning right after starting the car up. I cleared all of the codes yesterday to see if the ECM-917F or ECM-951F codes came back during my trip to my appt and back today, and when I did the extended code scan there wasn't anything there when I got home. Makes me wonder what that message was for, and why it decided to pop up when I first started the car this morning. I still don't feel comfortable driving it out of town yet, but I may have to take it to the Volvo dealership an hour and a half away to figure out what the problem is since it's still not running right.
Post by cn90 »
Do you have an ebay account?
Search ebay for a more recent gas pedal, such as from a newer car with low mileage.
It is rare but sometimes the ebay seller lists exactly where the part comes from (which year, model, mileage).
Let us know if you can find one on ebay.
If not, I can search through my local junk yards...
PS: the Volvo dealership will drain whatever money you have remaining in your bank account.
