So, it's been about 8 years since I've been here. I have yet to land another 850 BUT that could possibly change in the next few days depending on what you guys say.
There's an 850 Wagon up for sale on Offerup for only $500. The owner says "Smokey exhaust with rough idle."
My question is: What could cause this kind of a problem? Smokey exhaust? Rough idle I'm going to assume maybe it needs a tune up or something, but smoke in the exhaust is my biggest concern. He's selling it for best offer so if the problem isn't too bad maybe I offer him $350-$400 for it and take a few hundred to get it running right.
Welp... I want another 850... Maybe this time's the charm?
It’s usually $1500-2000 to get an old P80 to a Stage zero
- Has thanked: 311 times
- Been thanked: 817 times
Smoky exhaust is usually burning oil (which burns gray) due to worn out valve stem seals which is a bunch of head work to fix, or you can live with it the smoke and oil consumption. Smoke may also be unburnt fuel (which leads to black smoke, running rich) from poor running condition. If it smokes all the time then the running rich is actually more likely.
I'd find out what color the smoke is.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Remember: there is no thing as a cheap p80. The lower the base price, the more you dump into it.
But for a few hundred you can give it a shot if it looks solid and not too badly abused.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- RickHaleParker
- Been thanked: 977 times
Look at the color and smell.krush wrote: 05 Oct 2020, 19:58 My question is: What could cause this kind of a problem? Smokey exhaust? .
White smells like steam because it is steam. Water getting into the combustion cylinders.
Blue, Blue-gray, Gray smells like oil because it is oil. Most likely valve stem seals. Could be turbo seals. Extreme cases piston rings.
Black smells like fuel is incomplete combustion. Not all the fuel is getting burnt. Needs tune up, possibly a set of injectors.
Active
Past
Past
Green smoke..frogs in the fuel tank
Blue smoke..the car has been used for smurfing
Orange smoke....someone put Tang in the Tank
So I got two replies:
I asked what year it was and if it was currently driveable:
“96 no turbo yes turns on and is drivable just that the idle acts up"
Then asked what color the smoke was:
“The color it smokes is black "
Looks like tune-up and injectors. I'm going to offer him $400 to "take it off of his hands".
How hard is it to change the injectors on this thing?
- RickHaleParker
Active
Past
Past
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Changing them is very easy, and replacement o-rings are still available. Finding replacements is much harder (in the UK at any rate, I can't speak for the US), but cleaning is a viable option.
Yeah, just send them out for cleaning and refresh, they will be good as new.
- 34 Replies
- 4015 Views
- 25 Replies
- 7040 Views
Last post by Blacklab467
- 2052 Views
Last post by foggydogg
- 1640 Views
Last post by Caffeind
- 427 Views
Last post by Dtp367
