I have tabulated all the part numbers I can find and post images below.
For -1996, it is Hellacious journey into chassis breaks.
From 1997-on isn't too bad
Format is current part number and superseded part numbers in parentheses.
P80 Axle shaft Part numbers tabulation, Version 1
- Been thanked: 4068 times
And here are the 15 variants of -1996 axles shafts.
- Has thanked: 311 times
- Been thanked: 817 times
For the record: I have swapped axles around from my two 96 860s to other P80 cars 95-98 without ever paying attention to part numbers, and never had fitment issues.
These would all be automatic, FWD cars. Mix of turbo and non-turbo although running NA axles in a turbo is not recommended, the outer CVs are not as beefy. I've run turbo axles in NA cars however.
My 1999 had the CV ball and cage style on the driver side, both ends , while earlier models I believe use the spider type.
All those part numbers and yet compatibility still to be determined...
Let’s tabulate part numbers andapplícations here in this thread, thanks erik
yes, 99+ are completely different axles from -98 and they are not interchangeable. Frankly I would suggest devoting separate threads to each to help clarify that for others down the road.
OK I will pipe down here unless posting part numbers ...
Didn’t mean to shut you down at all.erikv11 wrote: 30 Jun 2020, 19:18 yes, 99+ are completely different axles from pre-98. OK I will pipe down unless posting part numbers ...
I’ll be trying to fit a pass axle from a 1998 AT FWD TO a 1998 MT FWD shortly, stay tuned .
Update: failed
Update: failed
Chcek the shaft diameter, the axle seal may be different.
Thanks , will do. Obvious first check
Well, obvious now
Well, obvious now
The. Charleston…
- 1437 Views
- 1794 Views
- 16 Replies
- 2146 Views
- 9 Replies
- 3819 Views
- 508 Views
Last post by SonicAdventure
