1998 V70 LPT pcv replacement 244k miles
Has thanked: 2207 times
Been thanked: 1852 times
Thanks Erik. I knew 58" was in there somewhere!! I was in a rush yesterday and did not sully read the thread so appreciate your catch on the type of pipe to use.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
The only issues I have with the brass barbed 90* is that because it's a hard 90* turn I feel that it doesn't flow as well as a curved sweep 90.
Also the inside diameter of the fitting is way smaller than 5/8", which also restricts flow. The spring inside the hose prevents it from collapsing while not restricting the flow.
Just my .02 cents...
1999 V70 GLT
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
erikv11 wrote: 14 Oct 2020, 16:15
scot850 wrote: 13 Oct 2020, 20:52 Couldn't remember all the details as I have not done this repair personally. However, this is a long thread but most of the info is at the front. 3/8" not 5/8" as per my faulty memory!!
viewtopic.php?f=1&t=53448&hilit=PCV+modification
A serious flaw in the procedures described in that link is using cheap heater hose. Cheap heater hose has two potential problems (1) it can kink and collapse under the manifold where the hose makes a 90 degree bend, clogging the PCV and (2) it is not oil resistant and may eventually turn to mush again clogging the PCV. MVS member tryingbe put together the best solution, he used fuel line or some other oil resistant hose and a 5/8 brass barbed 90 degree elbow for the bend under the manifold.
Good stuff, don't think about those minor majors. Transmission hose would work also.
Sufbug
Year and Model: 1998 V70
Has thanked: 2 times
Post by Sufbug »
Thanks. I started today and gonna get back on it for a little bit.
I took a bunch of pics! Woot woot!
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
Sufbug
Post by Sufbug »
how much turbo tubes come off. Still have to get the top of the aitrbox out of the car.....do I have to remove that down by the turbo?
intake water hose and bolt under neath...wtffff lol
have to go buy 5/8 fuel line upgrade
Why to I need the home depot hose clamp?
Some questions...
MoVolvos
Post by MoVolvos »
That thing is clean! Can't see exactly what wheels you have but it looks nice also.
Sufbug
Post by Sufbug »
Thanks MOVOLVOS!!!!!
Yeah it's kinda good-looking , some dents and stuff. Here are a few more pics
Those are the wheels. And the others are before a mini detail
Please note the IPD lic frame, small ipd sticker, and HUUUUUGE dive bomber aka P-51 muffler tip!
I gonna go chip away at it right now. Gotta get the manifold out of the way!
Helppppppp lol
mkc1
Year and Model: 850 GLT 1997
Has thanked: 27 times
Been thanked: 10 times
Post by mkc1 »
Did mine last weekend with the Genuine Volvo kit from IPD. All went well except when trying to replace the O-ring on the first injector (figured I might as well do it since the kit included them) the pintle cap on the injector broke. So, if you do decided to replace the O-rings be very careful not to break the pintle cap -- mine are old and brittle.
My parts car had a full complement of injectors, so I just replaced the injector. Ran a bit rough at first and threw some misfire codes on cylinders 1 and 2, maybe because of air that got into the fuel rail when I replaced the injector. Maybe should've primed the fuel system by turning the key off and on a few times to operate the fuel pump.
"Learning mechanics is easier than learning male psychology. You can figure out an engine; you can never figure out a man." -- Pepa Marcos, Mujeres al borde de un ataque de nervios [paraphrased]
1997 850 GLT "Volvo"
1997 850 AWD "Junior" (for parts, sadly)
Sufbug
Post by Sufbug »
mkc1 wrote: 17 Oct 2020, 07:58 Did mine last weekend with the Genuine Volvo kit from IPD. All went well except when trying to replace the O-ring on the first injector (figured I might as well do it since the kit included them) the pintle cap on the injector broke. So, if you do decided to replace the O-rings be very careful not to break the pintle cap -- mine are old and brittle.
Pintle caps are all messed up. I can I can put the ring o-ring on it however the small plastic piece that holds the o-ring on the injector is broken see my pics
The hardest thing is getting the bolts off the manifold I suggest having a lot of extensions a lot of different size socket heads tall and short and have socket knuckles or whatever they're called so you can position the socket on directly on the bolt
I am working on the last manifold bolt near the power steering and coolant hose intake. Ouch!
And may be time to replace the spark plugs. Hahaha see pics.
Hmmmm these things are fussy about plugs. Correct?
What kind should I use ? Model number , type?
Thanks. At least we are making headway over here!
Big Al
Sufbug
Post by Sufbug »
Yeah I'm very close! Can't get the oil dipstick bolt loose, and the ones from under the manifold.
I did one bolt off the manifold rest bracket. From the bracket to the engine block...that 12 mm bolt. Hope that's correct!
Also replaced the plugs while they were looking right at me! Haha
I used antisieze, the prior tech didn't, and I put in BKR6ES made by NGK . gapped aT .028
$2.99 each!
Have to figure out the torque amount and go grab my torque wrench. Ahhhhhh 18 lb ft or. Hand tighten. And then 1/4 turn
