Brake pedal position sensor replacement alternatives?
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
Not really, but I'm tired of swapping cars all the time because they break down on me. Plus I want something that's going to be reliable, and last a long time.
If I could go back in time I would have kept my 1958 Chevy Biscayne 4 door. It was around 90% restored, my daily driver, and it turned heads everywhere I went. Never saw another 4 door like it in any of the car shows I was in, and haven't seen another one since I got rid of mine. Live and learn, I just tend to do it the hard way.
That sensor won’t alter brake action. As long as your brake lights are working, no safety issues.
The cruise will be disabled if the ECU doesn’t like the readings it gets from the position sensor as it uses that sensor to drop cruise control on braking. It is probably designed fail safe so that if the voltage from the sensor is absent, cruise is turned off
- gnalan
Brake lights work fine.
Any chance while using the cruise control and hitting the brakes that it won't shut off the cruise control or allow the car to slow down?
I don’t know the code but when my clutch switch went wonky cruise was disabled. If you start the car, cycle the brake pedal, engage cruise, then test it, you will be finegnalan wrote: 17 Oct 2020, 12:55 Brake lights work fine.
- 5119 Views
Last post by Raindog92
- 5262 Views
Last post by precopster
- 7062 Views
Last post by zjevik
- 3810 Views
Last post by Goldchemist
- 305 Views
Last post by rsmigel
