Has thanked: 1506 times
Been thanked: 3819 times
Do a voltage drop test on each battery cable at each point , Bruno
The cable do get crusty inside after 20 years, and can fail intermittently.
With the lights on, Measure b+ voltage directly across battery. Now move the negative probe to the ground and see how much the measure voltage changes. That will give you an idea of the negative cable condition.
Negative probe back on battery terminal. Now move the positive probe to the ends of the red cables and look at the voltage with lights on.
This badly needs a video link, will search for a good one
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
The positive and the B+ cables had been changed by the PO, so I wonder if there's an ongoing issue lurking.
Never a dull moment!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
brunocerous wrote: 17 Oct 2020, 07:44 The positive and the B+ cables had been changed by the PO, so I wonder if there's an ongoing issue lurking.
Ah, if that's the case then it would probably be worth looking into.
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
So after saving up some funds, I took my S70 to the Volvo dealer for a new axle. Turned out the former one was... too long?! That explained some of the noises. I've heard you guys say alot about aftermarket axles, how they are rubbish and brake down, but my Volvo dealer placed an aftermarket product. They said they searched everywhere, even called different Volvo-dealers in Sweden, but they couldn't find an original anymore :-( Well, the new axle drives like a charm, no more clunky noises in sharp corners, so that's a plus.
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
UK supply of driveshafts (and outer CVs) dried up about 10 years ago, according to long term owners. Breaker-yards are barren too, and have been for almost 5 years (thank you, Scrappage Scheme...). We've been using aftermarket driveshafts for a while as a result, though mostly sourced from well-known driveshaft specialist sources. As always and with anything, quality aftermarket should pose no issue - but unknown or smaller brands should generally be avoided.
5rivers
Year and Model: V70 1998 T5
Been thanked: 14 times
Post by 5rivers »
I don't remember the power steering lines being so difficult to remove, but I was able to cut them between the rack and front part of the subframe before the lines turn up to the pump/reservoir. I used a pair of bolt cutters, vice grips, and a hack saw. The vice grips were helpful in moving each line back and forth until the cut parts became separated. Closer to the rack I had to use a hack saw! Now it's the connections at each end of a line to loosen.
The stuck 13mm open end wrench finally came looose after I applied some heat to the bolt head and put an enormous amount of pressure to the stuck part of the wrench with a pry bar! Stuck the end of the pry bar underneath the stuck part and just kept pushing up until the wrench popped off!! Was then able to remove the bolt to the "beaver tail", but now the tail won't come out so I can get to the bottom part of the mount still bolted to the rack. I have tried raising and lowering the subframe and/or motor, all to no avail. There is almost enough room to slide it out behind the rack, but the O2 sensor is in the way. The arm attachment to the mount from the motor gets in the way when I try to slide it out in front of the rack! I think I might have to either remove the control arm bolts/nuts or undo the bolt(s) at the column holding up the steering rack. Just not sure which to try first! I need another half inch to an inch for the tail to clear the part of the rack where the mount is attached.
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
5rivers
Post by 5rivers »
A pic of the power steering lines at the rack, almost ready to be removed (waiting for pb blaster to work!).
The old rear motor mount (bottom part still attached to the rack) and new mount:
5rivers
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Brakes bled! Old stuff looked really yucky...
BMW 540i 2002
S70 Base 2000
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1002 times
Post by volvolugnut »
kallekula wrote: 18 Oct 2020, 16:36 Brakes bled! Old stuff looked really yucky...
That is nasty!
Cookeh
Post by Cookeh »
Are those discs dimpled or drilled?
