Brake Booster Vac Line Replacement
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It's that or valve is on it's way out.
I vote for a bad vacuum hose.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 2205 times
Been thanked: 1852 times
+1 with misha on this. If the issue is mostly when cold, it is most likely the plastic one way valve on the front of the booster where the vacuum pipe from the intake goes to the booster. The first sign this is failing is when you get a hard pedal in the morning or when sitting for some time. Pull one from the junkyard and swap it out. They do fail but not often.
vovo850
Year and Model: 1995 850 glt
Has thanked: 49 times
Post by vovo850 »
Thanks guys, I obviously didn't look at it yet but I was sweating it was the ABS.
This makes me feel easier, sorry for the hijack.
1995 Volvo 850 GLT N/A automatic wagon
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
HI, I'm bumping this old thread because I haven't been able to find the hose on the parts diagrams. Mine, of course, was disintegrated and hard as a brick and I'm currently running on a length of Gates transmission oil hose. The wall is about 2/3 as thick as what I took off and it seemed pretty squishy but it's working for now. It seems less than ideal and I'm wondering what others have done.
Has thanked: 311 times
Been thanked: 817 times
I replaced one with thick walled silicone hose. Definitely squishier than the factory hose but has worked well for several years.
