Seeking exhaust recommendation for Whitey: 1998 v70 AWD
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
Whitey needs its exhaust system replaced. Previous owner used a European import, 304 stainless steel at best. He reported quality and fitment issues. I like the two muffler appearance, but am not wedded to that idea. Does anyone have any opinions on how to move ahead? Thanks!
Whitey's tail.pdf- (24.76 MiB) Downloaded 194 times
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
- Has thanked: 2215 times
- Been thanked: 1853 times
Not sure how much it will cost but looking at having a custom system built in T304. If that system you have is T304 it should not be rusted. Most aftermarket systems are expensive and made from crap like T409 which is no better than mild steel.
I have seen T304 systems out there but mostly in Europe.
Dual OE systems are NA for years unfortunately.
- Has thanked: 1613 times
- Been thanked: 4078 times
Courtesy of wisechatmgr
Parts geek.com
API 2103_75006-5
Aftermarket two can system
https://www.partsgeek.com/catalog/1999/ ... ffler.html
Not too bad, about $135
You need the pipe to connect to the cat too, another $40 or so
Will last 5 VT summers or one winter
Parts geek.com
API 2103_75006-5
That is a good find! May have to look at this for my car. For a car that does very little mileage like mine and does not do a lot outside in winter, this may be worth it!
Thanks for sharing!
Thanks for sharing!
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Indeed a good find. I am assuming that a cheap system like this does not have great rust protection and the material can't be high quality either.
But maybe coating it with something before installation could extend the life, perhaps even a thick coating or two of painted on zinc primer. It doesn't get that hot back there so that should be no problem.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
markone
Thank you for the suggestions. Seems to be a barbell situation- El Cheapo on one end, custom 304 (maybe $1,200) on the other. Not much in the middle, huh?
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I recently bought a Ferrita cat-back system from Viva Performance in 304 stainless for my 850. It was made in Sweden and cost about $700 delivered. Quality was quite good, and it came with stainless clamps and high quality rubber hangers. They have a few options for V70.
I read that last option as ‘ Feral cat’
My dylsexia is really getting bad, now.
markone
When I asked the folks at Viva for recommendations, this is what they came back with:
Downpipe:
https://www.vivaperformance.com/tme-per ... s-v70-awd/
Exhaust:
https://www.vivaperformance.com/exhaust ... 0-v70-awd/
https://www.vivaperformance.com/ferrita ... 0-v70-awd/
https://www.vivaperformance.com/tme-exh ... 0-v70-awd/
All of these exhausts are made in Sweden, Ferrita, Viva and TME. Two week lead times, roughly.
Downpipe:
Exhaust:
- Has thanked: 987 times
- Been thanked: 1078 times
SO, that could be rated as VT 5S/1W? Perhaps we can get other exhaust VT rated?abscate wrote: 21 Oct 2020, 14:08 Courtesy of wisechatmgr
Parts geek.com
API 2103_75006-5
Volvolugnuty
- 11 Replies
- 2198 Views
- 343 Views
Last post by Andrewoakland
- 9388 Views
Last post by Coldheart99
- 971 Views
Last post by odaikorob
- 3759 Views
Last post by IG-88A
