Financial Distress Parts Program
- Has thanked: 2857 times
- Been thanked: 1332 times
^ too true
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
I've posted in the junkyard request thread, in the classified's sub forum, for other parts that I need.
This is a great program, and it helped me a lot. I can't thank everyone enough for the parts, advice, and the support I received.
- liambean
- Has thanked: 27 times
- Been thanked: 3 times
I recently changed the lug bolts on my 2001 (P2) V70 to lug studs and nuts. The Hex head is 19mm. The bolt length is 55mm from end to end. Please note that these were zinc coated, not chrome. There is some surface rust on the heads, and the bolts are a bit dirty with surface grease.
That means I have twenty (20) used (twenty years old) lug bolts that I can "donate" to this program. I'll mail them anywhere in the lower 48. Just let me know where.
Picture not representative of bolt state.
- liambean
Since I changed the wheel mounts to studs and lug nuts, I no longer need the factory lug wrench / pry bar. The Hex end is 19mm. Though the car is 20 years old, I don't think this has ever been used as it looks brand new.
- Been thanked: 4068 times
I dispatched
2 front brake rotors
2 calipers
2 sets decent front brake pads
Pass headlight
SAS pump
Front radiator frame member
Cam sensor
Radiator
Rear number brackets
On the FDPP program to a car in progress
We thank all of you who donated parts and via donation to this program
2 calipers
Pass headlight
SAS pump
Cam sensor
Radiator
hipcheck
- Year and Model: 1997 850
- Has thanked: 6 times
- Been thanked: 7 times
Not sure if you just post here or not?
I’m not distressed from Covid or a layoff, however, I have recently wrecked my front end. I was able to find a donor for the passenger side fender, bumper, lower bumper cover, hood and grill. I also had to purchase a new radiator/AC condenser while at it. I do still need a decent set of headlights and corner/blinkers
I sent a few PM’s to people in the classifieds that had a set but they are offline I guess
If you have any used headlights ( I need the whole thing) and also the corners too.
Would prefer a matches set, but anything can get me back up and running and serve as spares later?
This is for a 1997 850 T-5 Wagon
Thank you,
Steve
Thank you,
Steve
I believe I have both headlamp assemblies and corners.hipcheck wrote: 29 Oct 2020, 16:29 ...
Thank you,
Steve
You guys can come to a mutual satisfying arrangement by private message or email , no need for third party meddling
BIg Red , thanks in advance - I hope that’s Cornell Big Red!
Sufbug
- Year and Model: 1998 V70
- Has thanked: 2 times
- Been thanked: 2 times
Little crazy, but I need intake manifold bolts the ones that are about 2.5 to 3 inches long. For a 98 v70 wagon GLT with the low pressure turbo. I need two of those bolts please. Message me and I will give you my address. Also, I can venmo a few dollars to cover postage / handling. THANK YOU!!! Allen aka Big Al
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
