The Resurrection/Insurrection of GrunHilde - 1998 V70 NA M56 421 Green
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Guilty here.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
abscate wrote: 22 Oct 2020, 02:57 Why is it after promising to divest if projects I know have six Volvo’s in the yard? Plus two more in the front driveway?
Not sure about you but I tell mine it just as effective and more cost effective then Psychotherapy. Furthermore there is something to show for it after the money is gone. :wink:
Active
Past
Has thanked: 1611 times
Been thanked: 4075 times
Keep your eye on the prize.....
Put on the split boot from Dorman with superglue edges. This is a nice repair
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
Interested in a long term review of the split boot.
Did well today
REPlaced passenger side CV boot with split one
Reinstalled knuckles , axles, struts, hardware , brakes
Good meat
Pushed 250 ml brake fluid through both front calipers
Changed m56 gear oil to mobIl 1 synthetic
Has thanked: 2210 times
Been thanked: 1852 times
Is that the same car?? Are you sure it is not one of the 'others' you are actually showing us? Cannot believe in the difference in the front end suspension and brakes, knuckles etc. Where has all the rust gone. Most impressed!! :D
It's incredible
Here are the before and after.
Kudos to Sonic for unloading the 1998 carcass for cheap which made this a Labor only endeavor, pretty much
SonicAdventure
Year and Model: 1996 850 wagon
Has thanked: 59 times
Been thanked: 12 times
Post by SonicAdventure »
Nice work! How much is left of that black '98? It must be picked pretty clean by now. Did you use the control arms from that one for the green one? The passenger side control arm is only 2-3 years old, not sure about the driver side.
It’s pretty picked over....
The local University is sending Anthropology students over to study the remains for field work...
