Guilty here.
The Resurrection/Insurrection of GrunHilde - 1998 V70 NA M56 421 Green
- Has thanked: 987 times
- Been thanked: 1078 times
- RickHaleParker
- Been thanked: 981 times
Not sure about you but I tell mine it just as effective and more cost effective then Psychotherapy. Furthermore there is something to show for it after the money is gone.abscate wrote: 22 Oct 2020, 02:57 Why is it after promising to divest if projects I know have six Volvo’s in the yard? Plus two more in the front driveway?
Active
Past
Past
- Has thanked: 1614 times
- Been thanked: 4078 times
Keep your eye on the prize.....
Put on the split boot from Dorman with superglue edges. This is a nice repair
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Interested in a long term review of the split boot.
Did well today
REPlaced passenger side CV boot with split one
Reinstalled knuckles , axles, struts, hardware , brakes
Good meat
Pushed 250 ml brake fluid through both front calipers
Changed m56 gear oil to mobIl 1 synthetic
Good meat
- Has thanked: 2215 times
- Been thanked: 1853 times
Is that the same car?? Are you sure it is not one of the 'others' you are actually showing us? Cannot believe in the difference in the front end suspension and brakes, knuckles etc. Where has all the rust gone. Most impressed!!
It's incredible
Here are the before and after.
Kudos to Sonic for unloading the 1998 carcass for cheap which made this a Labor only endeavor, pretty much
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
Nice work! How much is left of that black '98? It must be picked pretty clean by now. Did you use the control arms from that one for the green one? The passenger side control arm is only 2-3 years old, not sure about the driver side.
It’s pretty picked over....
The local University is sending Anthropology students over to study the remains for field work...
- 1147 Views
Last post by FLXC90
- 303 Replies
- 38607 Views
Last post by bmdubya1198
- 15 Replies
- 2686 Views
Last post by Arathi
- 2868 Views
Last post by Brick850
- 900 Views
Last post by 93Regina
