The Resurrection/Insurrection of GrunHilde - 1998 V70 NA M56 421 Green
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Rover wasteland.JPG (81.98 KiB) Viewed 1110 times
Has thanked: 1611 times
Been thanked: 4071 times
Dropped the heater core for replacement. Was original Volvo / Behr from late 1997
Firmed up, not final torque to front end bolts
Installed snow tires, and dropped her back onto her feet, and took her for a test drive!
All well.
Has thanked: 2207 times
Been thanked: 1852 times
That is awesome news after all the work you have done on GrunHilde. Hopefully she will respond with a lot of good service for whoever the lucky person is who gets her.
Have you any more things you still have to do to complete this project?
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
Maybe "final torque" those front end bolts?
Left front abs sensor wires
Final torque front end
Final torque 36mm castle nuts
E brake
Rear tires
Heater core install
Reinstall alternator
Interior cleaning
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
You're a darn machine with the speed you're working on that =)
2023 Lexus RZ450e -66k
Got an eBay alternator and dropped it in. New serp belt,viciously tight. It ran very well with no tensioner. Could not install belt with tensioner , even after running for ten minutes.
Struggled to put tensioner back on with belt on, finally did using bottom bolt first on tensioner trick
Wisechatmgr figured this all out, he was on A game yesterday
Fuel leak stopped
Found a 2015 heater core in parts, will use that
Lost heater core bolt, torxt25 m5 x 15 mm. 986200
Have spare
Periodically stopped in for moral support painting living room
wizechatmgr
We had a room at the plaza that was painted Xerox red... It had to be repainted because apparently somehow subconsciously it causes people to fight.
It became an ugly green instead.
That belt was tighter than any belt I've dealt with before. I don't think the tensioner even did a full 1mm of movement when I removed the pin. I swear they made it a half inch or so short. At least it sparkles =P
ANd we are done under the hood!!!
Got a 2016 Heater core from stash - replaced, removed 5/8 bypass - silcone grease on o-rings, leak tested with water, then hooked up coolant.
No leaks - great heat in car.
Miles 184006
Radio code 5415
