2002 S60 Misfire (it seems) but not throwing code
algopyguy
Year and Model: 2002 S60 2.4 Base
Post by algopyguy »
2002 s60 non turbo.. Been trying to hunt down a rough idle and misfire issue for a while now.. I am not getting a misfire code in vdash or my cheapy obd reader..
I've checked plugs and regapped them, checked coils with a spare spark plug and they all seem to work.. Pulled the fuel pump rail and had someone turn the key and fuel injections seem OK (proper spray)..
So at this point I'm scratching my head as to why she's running so rough.. She idles around 1,000rpm at idle which seems high to me as well
Here is what she sounds like by the muffler...
https://gofile.io/d/lOmX2U
Looking for next guidance as to what to check next..ty
algopyguy
Post by algopyguy »
Also I did a compression test on the engine warm and 175-180psi across all cylinders.. Not sure what the range should be
algopyguy
Post by algopyguy »
Just read about the ETM whine test.. So when I turn ignition on I get the whine then a click but whine doesn't go away.. ETM failure? Its a white label ETM from a yard..
Been thanked: 4068 times
Compression is fine
The ETM should whine for 8 seconds then go thunk. After that, quiet
Pull the date code off the etm , they went from early white label, to yellow label, back to white label.
Just like sharknado, the third one is best
