Dash indicator that I can't read ......
Duncx
Year and Model: V70 2.5t AWD 2005
Post by Duncx »
2005 Volvo V70 2.5T AWD estate/wagon
My dash keeps flashing up "panne d'ampoule feu de position" after I hooked up mate's trailer ..... car originally sold in Quebec and no I don't speak French. And yes I googled it but all results are in French and I don't understand them.
Seems to be saying "position light" out but I have looked all around the car and everything looks good (no trailer plugged in now). It flashes on and off all the time and with no specific pattern etc..
Any pointers would be awesome.
Cheers.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Duncx wrote: 31 Oct 2020, 13:20 Any pointers would be awesome.
Cheers.
Maybe better to reprogram DIM to English?
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
I have a Swedish speaking DIM, i'll swap ya French is much easier to understand
Swedish DIM
Swedish DIM
dim in svenska.png (439.04 KiB) Viewed 1226 times
2001 XC70 factory M58
2002 XC70 auto (parts car)
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
I would be looking for Wire Chafing on his trailer. You will get that message if a light circuit shorts to ground. It is intermittent, which indicates a harness moving, which in turn can cause chafing ....
Active
Past
Has thanked: 1611 times
Been thanked: 4072 times
When it starts texting
Non, he ne regrette rien
You know you have real problems
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
That would be indeed faulty position light bulb, there's two of these very fragile bulbs in each tail light, possible the small tungsten has cracked on one and still makes intermittent contact. May also pull the bulb and inspect the socket for corrosion.
As mentioned, it's a good idea to at least write down most common important messages in french, have the paper with you
Mostly messages with charge batterie or systeme electrique (battery charge, usually faulty alternator regulator), huile moteur (engine oil), niveau bas liquide refroidissement moteur (low engine coolant level), arreter (stop), anti patinage (anti-skid), freins (brakes)
I found a nice owner's manual, it has a few messages at page 43, unfortunately it's not all of them https://az685612.vo.msecnd.net/pdfs/28e ... tp8147.pdf
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
"No, he doesn't regret anything"....? Is this an example of literal translations and colloquailisms colliding?
It’s an Edith Piaf classic. You’ve heard it in many high end ads for expensive stuff on TV
RickHaleParker
oragex wrote: 01 Nov 2020, 06:43 I found a nice owner's manual, it has a few messages at page 43, unfortunately it's not all of them https://az685612.vo.msecnd.net/pdfs/28e ... tp8147.pdf
I found the one that matches his V70. :wink:
https://az685612.vo.msecnd.net/pdfs/6b0 ... tp7552.pdf
Active
Past
