Ok, Im really a cheapskate.... (oil use question)
Been thanked: 4069 times
πŸ˜€πŸ˜€πŸ˜€
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Ok, now fess up. Where did you reuse this lightly experienced oil?
Thats 7500 mile oil from Catherine. The 2005 V70 NA M 56
Synthetic really lasts a long time
Now that I finally fixed the oil leak on the T5 , though, ( turbo oil return line) it doesn’t use enough oil to warrant keeping used oil around, hardly,
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
I changed the oil in my motorcycle before putting it away for the winter, 550 miles on a gallon of Rotella t5 15/40. I'll use it in my daughter's s70 on her next oil change. Cut it with 2qts of 5w20, close enough.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Matty Moo wrote: 01 Nov 2020, 11:08 I changed the oil in my motorcycle before putting it away for the winter, 550 miles on a gallon of Rotella t5 15/40. I'll use it in my daughter's s70 on her next oil change. Cut it with 2qts of 5w20, close enough.
Better off with the T5 instead of the T6 on motorcycles. I found some additional clutch slippage with the Rotella T6. Obviously this depends on if you're using a wet clutch (such as my ninja) or a dry one in which case it won't matter =)
Fleet update
The Bavarian Money waster gets only 50 miles a week on her, so she will be my used oil Derrick
RaceBeetle running hard m 12k per year, regular oil changes
Evita theS70 running 10,000 per year, regular oil changes
Elizabeth T5 just back on line , probably 10,000 per year
Shaggkira V70 very light, on;y 2-3k per year. Short interval changes
Ludwig VW T4 tows, so she fed a 5000 mile Syn change
Catherine the p2 v70 running 7000 per year. Regular interval
The money waster is the only one using oil, maybe a liter every year or so.
2025 fleet update
Evita 1.5 mile work commute 3x weekly, one annual synthetic oil change
Catherine 5000 miles annual, one change synthetic
Elizabeth, low miles this year
Juliette Beetle - daily driver , one annual synthetic
NewGena xc90…no oil change yet
Ludwig Van VW t4 - off road at moment
Karla Kat s70 .upstate at cottage. Annual synthetic
