Volvo 854 NA to turbo Serious Topic is solved
volvoras
Year and Model: 1995 854 GLT
Has thanked: 9 times
Post by volvoras »
Hello, another broke university student with a dream here,
I have a EU 1995 GLT NA (B5254fs), and have been looking to turbocharging it, because t5 models are getting realy expensive and rare.
After doing A lot of research, I was wondering what is the difference between the eu na glt and us lpt glt /awd engine? The bore/stroke is the same, and from what Johann(project mjolmir the NA 200hp) has written the block oil passages and under piston sprayers are the same.
So the question is if the head is interchangeable with the lpt engine or are they the same?
And yes I know about the guy who did a NA+T, but i think the engine is capabe of 200+hp
If anyone has any information available or anything that might help, I would greatly appreciate it.
ps. I have an option to buy the awd engine w turbo and wiring with the computer for -+ 500€, while t5 cars are getting to 2,5k€+ if you can find them.
Has thanked: 1611 times
Been thanked: 4074 times
The compression ratio changes on the turbo and the valves are sodium filled.
Oil cooler has to be fitted.
New engine management
volvoras
Post by volvoras »
Ok, thanks
But does that mean I could switch the heads and the engine management system and be ok with it??
I forgot to mention i would also get an intercooler and the piping and the oil cooler
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Likely going to need a new harness. Can't imagine they'd run the wiring for all the extra stuff if they didn't have to...
Then again, this isn't a 99 so I'm unsure.
2023 Lexus RZ450e -66k
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
I don't know how hard it is to get a german car registered in Slovenia, but I'd rather try to find a decent T5, preferably 94 or 95, in Germany. In Autria, sometimes you can find cheap T5s as well, but they are rarer.
I'd definitely rarher spend 2.500 on a running Turbo car than 500 in parts plus extra parts you might have to replace, hours of labour, and guesswork.
My concern doing a wiring harness change would be bad connectuons or broken wires. All the connectors and the insulation gets brittle with time.
Also, the 99 definitely has a different ABS System than your 95.
1996 855 R,
2010 V70 D5,
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
Wiring is the smallest problem. You need to add just 2 extra wires to turbo control valve.
Pistons for turbo and NA engines are different. And it's desirable to use spattered big end bearings for turbo engine, they are expensive.
If my English is bad, please correct me :oops:
