The head of the engine was replaced recently is (had a timing belt/water pump failure that bent all the valves so we got a used engine from the yard).
Since then, when the car is cold, there is a big clunk on engaging drive. It goes away when warm.
Any ideas what it could be?
Clunk when cold engaging drive
moncureww
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 3 times
Is it axle ping? Mine (2006 s60 AWD) has an intermittent axle ping on engaging drive - doesn't happen all the time, but definitely a clunk when taking it from park to drive sometimes.
moncureww
I'm not quite sure - I wouldn't think that it would be dependent on the engine "warming up," but for some reason I notice my "clunk" or axle ping more when I'm just starting out after leaving the car parked for a while.
qwertyjjj
- Year and Model: V70 2004
When I rock the wheels with my foot I do get kind of a clicking sound though it's not exactly the same as the clunk when driving but that could be a speed thing.
Is it dangerous at all? It looks like a simple change, you just take a bolt out, puts new one in, and torque.
I assume if the bolt were to fail, you would just lose drive power to the car?
I'm guessing when they changed the engine, they had to take off the axle or something and the bolts are now worn
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
initial shifting can be bumpy when the transmission is cold, idle might still be high too.moncureww wrote: 04 Nov 2020, 20:17 I'm not quite sure - I wouldn't think that it would be dependent on the engine "warming up," but for some reason I notice my "clunk" or axle ping more when I'm just starting out after leaving the car parked for a while.
It may have more to do with trans temp than engine itself.
You won’t lose drive power of that bolt gets loose. It just holds the axle shaft tight in the bearing hub. The splines transfer the drive power. If it does get lose, it can cause an ABS code caused by the tone ring not being exactly in the right place relative to the ABS SENSORqwertyjjj wrote: 06 Nov 2020, 06:40 When I rock the wheels with my foot I do get kind of a clicking sound though it's not exactly the same as the clunk when driving but that could be a speed thing.
- RickHaleParker
- Been thanked: 978 times
It is not uncommon for a transmission to clunk when cold. Transmission fluid is a type of oil. Like any oil it thickens when it get cold. Also metal contracts when it gets cold tightening the tolerances. I pretty sure it not your engine warming up that makes the clunk go away. It is the transmission fluid warming up and getting circulation going that makes the clunk go away.
When it is cold letting it run for a minute or two might do the trick. Which is something you should be doing anyway, it extends the life of the engine. If it does not clunk. It pretty much confirms my guessanostic.
A transmission fluid change might do the trick. If anything don't get freaked out about the transmission clunking when its cold.
Active
Past
Past
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I had that problem, hard clunk going into drive or reverse from park cold or hot. Changed all the motor mounts and top mount with OEM, didn’t solve the problem, changed the B-4 servo also. Problem solved when I did a Transgo shift kit and rebuilt the linear solenoids, now it’s sooooo gentle going into drive or reverse.
2003 XC 70 (sold)
537playing
- Year and Model: 2005 S60
- Been thanked: 5 times
Blacklab467 wrote: 02 Jan 2021, 19:22 I had that problem, hard clunk going into drive or reverse from park cold or hot. Changed all the motor mounts and top mount with OEM, didn’t solve the problem, changed the B-4 servo also. Problem solved when I did a Transgo shift kit and rebuilt the linear solenoids, now it’s sooooo gentle going into drive or reverse.
You have peaked my interest in the shift kit. How was it done?
- 611 Views
Last post by jamie52
- 2241 Views
Last post by Kerpre
- 3548 Views
Last post by precopster
- 22 Replies
- 9333 Views
Last post by 5ft24
- 919 Views
Last post by Jat007
