Clunk when cold engaging drive
qwertyjjj
Year and Model: V70 2004
Post by qwertyjjj »
The head of the engine was replaced recently is (had a timing belt/water pump failure that bent all the valves so we got a used engine from the yard).
Since then, when the car is cold, there is a big clunk on engaging drive. It goes away when warm.
Any ideas what it could be?
moncureww
Year and Model: 2006 S60 2.5T AWD
Has thanked: 3 times
Post by moncureww »
Is it axle ping? Mine (2006 s60 AWD) has an intermittent axle ping on engaging drive - doesn't happen all the time, but definitely a clunk when taking it from park to drive sometimes.
qwertyjjj
Post by qwertyjjj »
Would axle ping disappear when the engine is warmed up? When warm if I go to park and then back into D there is no clunk
moncureww
Post by moncureww »
I'm not quite sure - I wouldn't think that it would be dependent on the engine "warming up," but for some reason I notice my "clunk" or axle ping more when I'm just starting out after leaving the car parked for a while.
qwertyjjj
Post by qwertyjjj »
When I rock the wheels with my foot I do get kind of a clicking sound though it's not exactly the same as the clunk when driving but that could be a speed thing.
Is it dangerous at all? It looks like a simple change, you just take a bolt out, puts new one in, and torque.
I assume if the bolt were to fail, you would just lose drive power to the car?
I'm guessing when they changed the engine, they had to take off the axle or something and the bolts are now worn
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
moncureww wrote: 04 Nov 2020, 20:17 I'm not quite sure - I wouldn't think that it would be dependent on the engine "warming up," but for some reason I notice my "clunk" or axle ping more when I'm just starting out after leaving the car parked for a while.
initial shifting can be bumpy when the transmission is cold, idle might still be high too.
It may have more to do with trans temp than engine itself.
Has thanked: 1611 times
Been thanked: 4071 times
qwertyjjj wrote: 06 Nov 2020, 06:40 When I rock the wheels with my foot I do get kind of a clicking sound though it's not exactly the same as the clunk when driving but that could be a speed thing.
You won’t lose drive power of that bolt gets loose. It just holds the axle shaft tight in the bearing hub. The splines transfer the drive power. If it does get lose, it can cause an ABS code caused by the tone ring not being exactly in the right place relative to the ABS SENSOR
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
It is not uncommon for a transmission to clunk when cold. Transmission fluid is a type of oil. Like any oil it thickens when it get cold. Also metal contracts when it gets cold tightening the tolerances. I pretty sure it not your engine warming up that makes the clunk go away. It is the transmission fluid warming up and getting circulation going that makes the clunk go away.
When it is cold letting it run for a minute or two might do the trick. Which is something you should be doing anyway, it extends the life of the engine. If it does not clunk. It pretty much confirms my guessanostic.
A transmission fluid change might do the trick. If anything don't get freaked out about the transmission clunking when its cold.
Active
Past
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
I had that problem, hard clunk going into drive or reverse from park cold or hot. Changed all the motor mounts and top mount with OEM, didn’t solve the problem, changed the B-4 servo also. Problem solved when I did a Transgo shift kit and rebuilt the linear solenoids, now it’s sooooo gentle going into drive or reverse.
2003 XC 70 (sold)
537playing
Year and Model: 2005 S60
Been thanked: 5 times
Post by 537playing »
Blacklab467 wrote: 02 Jan 2021, 19:22 I had that problem, hard clunk going into drive or reverse from park cold or hot. Changed all the motor mounts and top mount with OEM, didn’t solve the problem, changed the B-4 servo also. Problem solved when I did a Transgo shift kit and rebuilt the linear solenoids, now it’s sooooo gentle going into drive or reverse.
You have peaked my interest in the shift kit. How was it done?
