Sounds like a 1960 vw bug
Nathan79
Year and Model: 07 XC70
Been thanked: 4 times
Post by Nathan79 »
Hello Volvo Geniuses... (07 xc70 170k)
So I did a head job & replaced turbo along with all coil wiring. Went to start it up after re-assembly and it sounds exactly like a 1960 VW bug😩. I have checked and rechecked turbo & exhaust manifold nuts/bolts for tightness (I spoze there could be a bolt missing behind the engine in close proximity to manifold & turbo, that connects to the head). I've checked & rechecked spark plug holes & coil packs (although I have not tested coil packs while running to ensure functions). I've checked & rechecked timing...all 3 marks are good.
Any ideas or diagnosis procedures?
Thanks
Nathan
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
When it's cold....can you start it up and hold your hand in various places to see where any air is jetting out around the manifold? Did you use new gaskets and hardware? All torqued to spec?
Nathan79
Post by Nathan79 »
:evil:
BlackBart wrote: 03 Nov 2020, 12:48 When it's cold....can you start it up and hold your hand in various places to see where any air is jetting out around the manifold? Did you use new gaskets and hardware? All torqued to spec?
I have not tried "feeling for it" too extensively, but will tmrw morning. Yes... All new gaskets & head bolts torqued to spec.
Has thanked: 1497 times
Been thanked: 3810 times
You can also put a bit of marvel mystery oil into the manifold and look for smoke pouring out
If you used the individual manifold gaskets, my guess is one slipped off
Nathan79
Post by Nathan79 »
abscate wrote: 03 Nov 2020, 17:55 You can also put a bit of marvel mystery oil into the manifold and look for smoke pouring out
Hmmmm..... Yes. Individual gaskets.... We'll see tmrw morning
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Did the head get checked for warpage?
Nathan79
Post by Nathan79 »
Went to start the car yesterday morning, but wouldn't fire. Confirned timing... Started to try to get some oil in exhaust manifold by disassembling turbo mounts & as soon as I disconnected the downpipe some fuel came out. "Can't be good right"?
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
the sound was probably a flooded engine, confirmed by raw fuel in exh.
I'd pull the plugs and clear the cyls with the starter.
RickHaleParker
Nathan79 wrote: 05 Nov 2020, 07:41 soon as I disconnected the downpipe some fuel came out. "Can't be good right"?
Because it was running rough before and it would not start after sitting for a extended period. I'm think leaking fuel injector(s).
