v70 98 -- Spark Plug Torque Spec.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Can anyone tell me the proper torque spec. for plugs for a '98 v70, normally aspirated, manual trans.? Thanks much, Evan
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
18 lb/ft.
E Showell
Post by E Showell »
Thanks much.
'95 855 auto (sold)
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I just get them hand tight and then a quarter turn- this compresses the aluminum gasket built onto the spark plug and works out to about the same 18 ft. lbs.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Me too.:wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
Doublesecret trick: to avoid crossthreading aluminum engines like ours, put them in with surgical or aquarium tubing. Pop one end over the plug's electrical end, then lower it in and twist the other end. You can only thread them correctly that way.
Also -> Amazon link
Cp1024
Year and Model: 98 S70 NA
Post by Cp1024 »
matthew1 wrote: 17 Oct 2009, 17:32 Doublesecret trick: to avoid crossthreading aluminum engines like ours, put them in with surgical or aquarium tubing. Pop one end over the plug's electrical end, then lower it in and twist the other end. You can only thread them correctly that way.
I use a sparkplug wrench, any reason that I should stop?
Has thanked: 1613 times
Been thanked: 4077 times
If you start the wrench with an extension and your fingers, that’s fine. Don’t put the handle on until you have at least 3-4 turns of finger threading
If you are using a spark plug wrench in place of surgical tubing,I don’t think that’s approved yet.
