Good to see y'all! Long time no talk. I've been enjoying my 960 mostly, although it's been parked for the last week because of my brakes. Drove right into a concealed pothole, trashed the master cylinder! Doing COMPLETE brake job minus the rotors and calipers.
While that's sitting til Wednesday, I'm curious about how easy and minimal I can possibly make it to attempt replacing a bent/broken connecting rod on my 98 XC, the parts XC being the donor. I understand I need to remove the oil pan. I don't want to take off the head. Can I remove a CR and piston together WITHOUT removing the crankshaft and head? By that I mean: After unbolting the CR/cap, can I pull the piston down through the bottom of the bore, around the crankshaft?
Does anyone have a picture of a 2.3/2.4 with oil pan removed?
98 XC: removing a bent/broken connecting rod Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
First video 4:23. Although it's a different motor the crankshaft is in the way. In the second video you can tell you don't have enough room on the bottom for the piston ring compressor.
- MoVolvos
Excellent video of the 5 cylinder. I don't have enough knowledge on whether all the 5 cylinders are about the same?
- CIK7
Yes the p80 L5 is very similar. The 99+ models have that rear mounted oil cooler and plastic pickup tube. The -98 p80 and 9 series white blocks have metal pickup tube, as well as bottom mounted oil filter and pcv is separate from oil filter. I love that video though. Very helpful. I MIGHT decide to remove lower and upper oil pan to remove and replace cylinder #2. If not I'm gonna move forward by selling it with the parts car.MoVolvos wrote: 09 Nov 2020, 21:28 *
- Been thanked: 4071 times
I donβt think pistons are coming out the bottom without major surgery
yanga001
- Year and Model: 98/99/00 v/s70βs
- Has thanked: 62 times
- Been thanked: 115 times
someone needs to make some laparoscopic volvo surgery techniques. Make a small incision in the cylinder head, grab the broken connecting rod, tig weld suture the hole...
2008 S60 2.5T Auto (Sold)
- Has thanked: 987 times
- Been thanked: 1076 times
Nanobots maybe?yanga001 wrote: 10 Nov 2020, 07:21 someone needs to make some laparoscopic volvo surgery techniques. Make a small incision in the cylinder head, grab the broken connecting rod, tig weld suture the hole...
volvolugnuty
yanga001
Nanomachines son...
Also how did hitting a pothole trash the master cylinder? Ive hit a pothole big enough to turn my wheel square with no major damage to suspension in my last v70.
Hell, the brakes still work after i expertly navigated it horizontally into a tree.
makes you wonder about the craftsmanship of that non p80
/sarcasm
Sometimes, albeit rarely , questions are best left unasked
- MoVolvos
If you can get the crank out you might be able to do it?CIK7 wrote: 10 Nov 2020, 06:05Yes the p80 L5 is very similar. The 99+ models have that rear mounted oil cooler and plastic pickup tube. The -98 p80 and 9 series white blocks have metal pickup tube, as well as bottom mounted oil filter and pcv is separate from oil filter. I love that video though. Very helpful. I MIGHT decide to remove lower and upper oil pan to remove and replace cylinder #2. If not I'm gonna move forward by selling it with the parts car.MoVolvos wrote: 09 Nov 2020, 21:28 *
