DIY: 1998 V70 Axle CV Rubber Boots Tips/Tricks
This topic is in the MVS Volvo Repair Database » Do It Yourself CV Boot Repair - Volvo V70
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
The only boots I've been able to find are Rein. I used them for my 2000 R driver side axle, and it's been good so far, but I've only put maybe 800-1,000 miles on it.
Hopefully someone knows where to get quality axle boots, I need to rebuild an OE Volvo axle I have in the shed for my '98.
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
I’ve used the GKN 300597 boot on my 97 850 R and according to cn90’s info the inner boots are the same on the NA.
It is an Audi boot, but fits fine.
https://www.rmeuropean.com/Products/893 ... MFG60.aspx
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
Has thanked: 312 times
Been thanked: 818 times
There is so much thread bloat in these axle boots posts lol. Go to the definitive post from NorthernLights who first sorted this out, all correctly: viewtopic.php?f=1&t=64252.
You can just look at the first post, unless you are up for a discussion that winds all over the place. The GKN 300597 is what you want, it also goes by part number 893-498-201-B-M60. AutoHausAZ is usually a great source.
EDIT: Wow this is a good price too https://www.eeuroparts.com/Parts/183753 ... ns-300597/
bmdubya1198
erikv11 wrote: 16 Jun 2019, 17:44 There is so much thread bloat in these axle boots posts lol. Go to the definitive post from NorthernLights who first sorted this out, all correctly: viewtopic.php?f=1&t=64252.
Thanks for the link! I'll have to order some.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Got the Volvo compatible Audi boot for inner CV joint. Side-by-side it looks just right.
xHeart
Post by xHeart »
GNK rubber boots for inner and outer:
xHeart
Post by xHeart »
The method of uninstalling and installing axle used removing 2 bolts connecting strut to knuckle.
The axle is now back in the car, but there is a squeak when steering is rotated 2/3 way - like brake squeaking. It only happens during tight LEFT turn. Your thoughts?
Also discovered cracks hidden in the folds of the driveaxle cv boot -- perpetual repair.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
This is a bit of revival again, sorry. My outer CV boot has just split (MY96 850 T5M), and I have already ordered a GKN Lobro replacement. My question is, is it necessary to remove the entire axle, or can this be done 'in car'? If it is not possible, how much gearbox fluid will I lose?
bmdubya1198
Much easier to remove the axle and do it outside of the car. You'll have to hammer the hell out of the outer joint to remove it, then it goes back together fairly easily.
You shouldn't lose much fluid, if any. Especially if you only have the one corner of the car jacked up.
Has thanked: 1611 times
Been thanked: 4072 times
DORMAN makes a split boot that can be put on without removing the CV joint. I’m not sure if it can be done on car though.
I have been told you can’t get DORMAN parts in the UK but that doesn’t seem right.
