Oil Pan to Oil Cooler Seal Replacement
Steve H
Year and Model: 2008 S60 2.5T & XC70
Has thanked: 6 times
Been thanked: 10 times
Post by Steve H »
2008 Volvo S60 2.5T FWD. I have some slight oil seepage from the 2 seals that are between the oil cooler and the oil pan on the backside of the engine. Does anyone know if you can simply, during an oil change, remove the 4 mount bolt to the oil pan for the oil cooler and slide back the cooler enough to replace the seals without removing the 2 coolant lines from the cooler. Thank you for anyone's help on this one.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
I have done it in that manner without issue on Volvos a few times - not your exact year/vehicle. Regardless the car is in the air, the oil is drained, you have the parts so give it a go. There was plenty of play in the lines to remove, clean and replace.
Been thanked: 4069 times
You don’t even need to drain the oil. The cooler connects to internal oil lines in the sump and won’t drain the sumo when removed. You will lose 250-500 ml oil or so, estimated
Steve H
Post by Steve H »
I appreciate both responses. I plan to do the seal change with the next oil change.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
I can also confirm yes you can, ive done it recently. Your meant to use some grease on the seals, i used rubber grease and this also helps to keep them in place for assembly. do not go crazy tightening of those allen bolts.
2001 XC70 factory M58
2002 XC70 auto (parts car)
