Power steering fluid or ATF?
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: Power steering fluid or ATF?
Post by MoVolvos »
gnalan wrote: 17 Nov 2020, 19:00 How many quarts do I need to do a full flush and fill? (I prefer Castrol over Valvoline.)
Which of the two videos posted above would be the better choice to get all of the old fluid out and replaced with new fluid?
Use the steering wheel method and attach the hose at the pump reservoir inlet hose. I prefer the steering to pressure the fluid out rather than passively trying to pull everything out. I'm not so sure it can really pulling everything out. That video was reference for the hose connection. Happen to see it for the first time and was what I was trying to convey.
Check to see if there is a capacity in the manual and if not I believe two quarts should do it if the hose is not too long. Perhaps 3 quarts just in case. You should be able to see the fluid color difference to know you circulated all the old stuff out especially when it is coming out of the inlet hose to the reservoir.
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
darrylrobert wrote: 17 Nov 2020, 20:13 EDIT just checked its a PENRITE LDAS CHF 11s which is an Australian brand may not be available inter continental
https://www.fcpeuro.com/products/hydrau ... 1s-1-liter
$17.76/L, and made in Germany.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
in regards to system flushing, ive never done it, i would think it only needs to be done if you suspect there are pieces of debris in there otherwise i think its overdoing it. In my opinion the power steering system isnt all that important as long as it doesnt leak.
2001 XC70 factory M58
2002 XC70 auto (parts car)
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
In states Pentosin CHF 11S or its replacement
CHS 202, both green. 11S in green can 202 in
white can. Advance auto has them both, pricey,
yes. I believe they can be mixed, I think it took
a little over 2qts. for a full flush.
