Countless people are running the 2014D_RePack on all editions of Windows 10.Kazthebassman wrote: ↑17 Nov 2020, 21:19 Most if not all are Win7 only..there may be a compatible program for Win 10 available but it is certainly not the one I used. Good Luck
Object doesn't support property or method 'DiagnosticAllowed' vida 2014D
- RickHaleParker
- Been thanked: 958 times
Re: Object doesn't support property or method 'DiagnosticAllowed' vida 2014D
Kazthebassman
- Year and Model: C70 1999
- Has thanked: 2 times
The person asking stated he was running his Vida program on Win7, then 'upgraded' his computer to WIN 10. As I implied, my version of 2014D is not compatible with Win 10 and his may not be as well. They are not all created the same..Pirated stuff, you know. Not claiming to be an expert on any of this, just stating my experience with my 2014D and much research a few years ago. There had been evolutions prior to my version and it would seem afterwards as well. Sure there may/is a way to get some some 2014D to operate on Win 10 but being he was on Win7 with his Vida, the possibility of it being Win 10 compatible may not exist or require some software rewrite/addition of files, etc... If this "repack" you speak of has it all sorted, I would personally buy that Win 10 compatible software(with support from seller) and save the headaches, even if there might be a way. with the existing software. It was difficult enough to install even when my version was stated to be compatible with Win 7 only and I used Win7. I certainly would not wish to do it again. Perhaps others have more recent relevant information. Just wanted to make sure that the person asking is aware that some are not going to work on Win 10. I had seen some of what might be involved, if possible on your/his/other versions, it was much more involved than what took me several days to do on Win 7 with Win7 compatible Vida. If several days and the possibility of failure are of less consequence then $100..and one enjoys such..have fun.
mh4all
- Year and Model: 2008 C30 2.0d
- Been thanked: 2 times
Hey there folks,
the solution for this issue is prettey easy.
I'm always getting this problem on my Windows 10 VIDA Notebook after Microsoft releases Major Updates.
1.) Insert the Vida Installation DVD or mount the iso image.
2.) Navigate to the /Install/Utils folder on the DVD or iso-image with Windows Explorer.
3.) Adding EnableIEHostingx86.reg and EnableIEHostingx64.reg to the registry by double-click.
Done.
Hope this helps you.
Greetings,
mh4all
Done.
Greetings,
mh4all
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 35 times
- Been thanked: 41 times
Double Clicking on these two files fixes the issue titled in this thread!mh4all wrote: ↑25 Apr 2021, 04:05 Hey there folks,
Done.
Greetings,
mh4all
Got VIDA working for first time in over a year!
Thanks mh4all!
