Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Cookeh wrote: 18 Nov 2020, 11:20 Today I started removing my o/s driveshaft to replace the perished inner and split outer CV boot. Very successful all told... six hours in and rain has suspended play. So far I've irreparably bent a 5ft breaker bar removing the axle nut, then I've sheared off both nuts holding the control arm bushings to the subframes. This meant I had to cut the bolt heads off the bolts in order to remove the control arms (the balljoint bolt also sheared) and then drill the bolts out from the bushings.
Hey, at least the 12mm driveshaft carrier bolts came loose without issue.
So in other words it's going marvelously :wink:
But sometimes a sheared off bolt does actually save time. Sometimes.
1999 V70 GLT
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Sveedy wrote: 18 Nov 2020, 17:52
Usually when it's a through-bolt like for a strut or something.
Has thanked: 1613 times
Been thanked: 4078 times
bmdubya1198 wrote: 18 Nov 2020, 18:31
Why do I feel ill reading this ......
bmdubya1198
I feel ill looking at that!
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Looks like something James Cameron would find!
Current Volvos:
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 116 times
Post by Goupil »
Making some space to take the engine out with limited ceiling height
I replaced the radiator/intercooler last december, so it didn't take long to do it again 8) Even managed to limit the amount of spilled coolant/oil :mrgreen:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Goupil wrote: 19 Nov 2020, 12:29 Making some space to take the engine out with limited ceiling height
There is a way out other then up or down ... Foward.
Active
Past
bmdubya1198
That B8444S just looks too good sitting in that engine bay!
Let those 🐴 Horses run free....
Elizabeth took me and the the twins 200 miles to our cottage where we knocked down the garage and brought home the lumber for the job.
Have a whole trailer of C&D to Dump too....poor Elizabeth pulled this load through the Catskills. York’s, that tongue weight looks nasty heavy.
House project coming along...
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Sveedy wrote: 18 Nov 2020, 17:52 So in other words it's going marvelously :wink:
Positively swimmingly...! I got up two hours earlier today and broke out the LED worklights to remove the bearing mount and driveshaft. I replaced both boots, cleaned up the ABS tone ring and slapped the driveshaft back in. All in under an hour, which it what it should have taken originally!
I finally found a use for my whitworth socket set too...pressing the worn and damaged control arm bushings out. Everything is now ready to go when the new bushings and bolts arrive - which should be later today.
