Vida CEM swapping
sirloins
Year and Model: 2010 V50 T5 AWD M66
Been thanked: 3 times
Post by sirloins »
Yes I meant microseconds not ms :D whoops. Canbus speed is 500kbps.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
sirloins wrote: 18 Nov 2020, 23:04 Canbus speed is 500kbps.
P1 CEM . : HS CAN 500 kbps, LS CAN 125 kbps. ( Motorola S12, 2005 - 2013 depending on model)
P2 CEM-H: HS CAN 250 kbps, LS CAN 125 kbps. ( Motorola MC68386, 1999 - 2004 )
P2 CEM-L: HS CAN 500 kbps, LS CAN 250 kbps. ( Renesas M32C, 2005-2014 )
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Interesting. MY2005 XC70 has LS CAN 125 Kbps.
vtl
Post by vtl »
RickHaleParker wrote: 18 Nov 2020, 22:47
vtl wrote: 18 Nov 2020, 22:01 At 500 Kbps one clock is 2 us, even at 125 Kbps the resolution stays in a single digit us range, not ms.
Found this in the J2534 API: unsigned long Timestamp;/* receive message timestamp(in microseconds) */
Is it fast enough to do the crack?
Theoretically, yes. If the CAN receiver part of the DiCE works linearly and does not distort the latency even further, it probably can be used.
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
All P2 have interior CAN at 125 kbps.
RickHaleParker
T5Luke wrote: 19 Nov 2020, 08:07 All P2 have interior CAN at 125 kbps.
Interior CAN 🤨 ... P2s don't have indoors plumbing.
Active
Past
vtl
Post by vtl »
All of the communication related to this research work happened outside of MVS or any other English-native forum or community, in a very broken English. Plumbin', schlumbin'... Ваапсче пофик...
sirloins
Post by sirloins »
I don't have much time in the next couple of days, so I submitted a pull request on that repo with what I have currently.
I tried to keep the defaults working for the P2, but I put a comment in about what settings I used for my P1.
My next goal is to write my own SBL for the unit to dump flash, and then add support for the other standard commands (Write/Checksum etc). I'll see if I can do it in C so it is portable maybe to the P2 platform? Was originally going to learn to write assembly, but it wouldn't be as portable. Any suggestions let me know.
With an C SBL it would be possible I think to make many versions in order to work with the different modules on the P1 platform at least (CCM, DIM and CEM all use MC9S12 chips).
vtl
Post by vtl »
Yes, I got your PR, thanks! Let me verify it.
Also, 2.5 more successful cracks on P2 were reported! 0.5 is for the failing detection of the third byte, which I know is troublesome. I'm gathering folk's data to tune the algo.
T5Luke
Post by T5Luke »
RickHaleParker wrote: 19 Nov 2020, 08:30
How should be right? Is dodge wrong?
CAN-Interior (also known as CAN Interior High Speed/IHS)
quote from: http://www.dodgia.com/docont-888.html
