Vida CEM swapping
- RickHaleParker
- Been thanked: 958 times
P1 CEM . : HS CAN 500 kbps, LS CAN 125 kbps. ( Motorola S12, 2005 - 2013 depending on model)
P2 CEM-H: HS CAN 250 kbps, LS CAN 125 kbps. ( Motorola MC68386, 1999 - 2004 )
P2 CEM-L: HS CAN 500 kbps, LS CAN 250 kbps. ( Renesas M32C, 2005-2014 )
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Theoretically, yes. If the CAN receiver part of the DiCE works linearly and does not distort the latency even further, it probably can be used.RickHaleParker wrote: ↑18 Nov 2020, 22:47Found this in the J2534 API: unsigned long Timestamp;/* receive message timestamp(in microseconds) */
Is it fast enough to do the crack?
- RickHaleParker
Interior CAN
vtl
All of the communication related to this research work happened outside of MVS or any other English-native forum or community, in a very broken English. Plumbin', schlumbin'... Ваапсче пофик...
sirloins
- Year and Model: 2010 V50 T5 AWD M66
- Been thanked: 3 times
I don't have much time in the next couple of days, so I submitted a pull request on that repo with what I have currently.
I tried to keep the defaults working for the P2, but I put a comment in about what settings I used for my P1.
My next goal is to write my own SBL for the unit to dump flash, and then add support for the other standard commands (Write/Checksum etc). I'll see if I can do it in C so it is portable maybe to the P2 platform? Was originally going to learn to write assembly, but it wouldn't be as portable. Any suggestions let me know.
With an C SBL it would be possible I think to make many versions in order to work with the different modules on the P1 platform at least (CCM, DIM and CEM all use MC9S12 chips).
vtl
Yes, I got your PR, thanks! Let me verify it.
Also, 2.5 more successful cracks on P2 were reported! 0.5 is for the failing detection of the third byte, which I know is troublesome. I'm gathering folk's data to tune the algo.
T5Luke
- Year and Model: S60 T5 2001
- Has thanked: 11 times
- Been thanked: 130 times
How should be right? Is dodge wrong?
CAN-Interior (also known as CAN Interior High Speed/IHS)
quote from: http://www.dodgia.com/docont-888.html
- 6431 Views
Last post by RickHaleParker
- 8699 Views
Last post by forumoto
