I ordered parts thru IPD. One option was the hardware package via Corteco for $200.
Keep in mind that previously I installed a quick strut but just looking to send them back to IPD. So I’m having no parts to reuse.
But looking at the parts I ordered I’m seeing that the bump washer disc isn’t included with this package. Is this disc really a necessary part? The foam bump itself seems to have a washer built in it already.
Strut Assembly
537playing
- Year and Model: 2005 S60
- Been thanked: 5 times
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
There was a disc which "crumbled out of" a bump foam thing on one of my OE strut assemblies.
When I got to the other side the foam bumper wasn't as deteriorated and it held onto it's disc/washer. I overlooked it.
I reassembled that side without it and the height of the strut's center rod was clearly higher than on the side where I had installed said disc/washer.
All you might need to do is pick the disc/washer off the foam stuff.
I had to remove, recompress and include said disc/washer. The replacement struts had a built-in bumper function.
As I recall, the disc/washer engaged a shoulder and, as stated above, effected operational height.
I wasn't going to have an alignment done with my mismatched installation.
As it turned out, I never did have the alignment done. The car drove straight and my tires wore perfectly.
On that score you can make your own decision. People will be along to claim it has to be done.
I matched the relative positions of the lower 2 BIG bolts to the hardware involved.
- Has thanked: 1611 times
- Been thanked: 4075 times
If you’ve got a tractor it’s much safer, like this guy
Georgeandkira
Inspirational video of the longest order. Thanks
CUE: Jump to 7:00 for the real excitement. You'll thank me.
LESSON: Again, don't go anywhere without your big pinch bar.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
I hope that was a parts car he was destroying and not the car he was planning on fixing. I've done some pretty stupid things when I've gotten aggravated by a part that wouldn't come loose, but not enough to destroy the entire car like that. Is he going to use the chain with his truck to straighten the entire front clip now? What about the damage from yanking it off of the jackstands, and then pulling the car halfway across his neighborhood?
Maybe all he needed was one big pull from his truck, instead of the several light tugs he did. He did have it secured to the car by the other chain so he didn't need to be so gentle with it.
All joking aside, please don't ever attempt to do anything like that. Having a car fall off of jackstands can cause serious injuries.
Seriously, though, don't ever attempt that.
- gnalan
You can look at you VIN plate under the hood by the fender and find the factory suspension codes which originally came on your car. Depending on the year it's either an 8 digit code or a 12 digit code. Here's the 8 digit code breakdown.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Just want to say thanks for the hints and suggestion on the suspension parts.
My wagon just reached 150k miles and all suspension is original minus the sway bar links. The Sachs quick struts might be low quality but they make the OE struts and shocks for us. Next March I'll be taking apart my assemblies and replace everything besides the springs.
I'll also rebuild all the original control arms with new bushings and ball joints.
I'll probably replace the engine mounts at the same time.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
XC70Rider wrote: 22 Nov 2020, 16:12 Just want to say thanks for the hints and suggestion on the suspension parts.![]()
Sachs sells for aftermarket several qualities of struts. The quick struts are the cheapest ones. Then you have the Super Touring ones. And then the ones sold by Volvo and made by Sachs. All these have different quality and durability.
XC70Rider
FCP lists this Sachs strut as matching the Volvo 31200413 for $100oragex wrote: 22 Nov 2020, 16:51 Sachs sells for aftermarket several qualities of struts. The quick struts are the cheapest ones. Then you have the Super Touring ones. And then the ones sold by Volvo and made by Sachs. All these have different quality and durability.
https://www.fcpeuro.com/products/volvo- ... c-30645640
Tasca sells the Volvo 31200413 strut just $14 more at $114
https://www.tascaparts.com/oem-parts/vo ... t-31200413
Since they're just $14 more I'll most likely get the Volvo 31200413 strut from Tasca.
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
i picked up sachs from erie half the cost and lifetime guarantee. one was bad they gave me shipping to return and sent me another
- 1550 Views
Last post by Bruce Nussman
- 2085 Views
Last post by Ludermilch
- 962 Views
Last post by durk80
- 1518 Views
Last post by jhnmartin
- 16 Replies
- 5572 Views
Last post by nyc1836
