cleaning water pump mating surface
januwan
Year and Model: 97 850 NA 205 K
Has thanked: 7 times
Been thanked: 3 times
Post by januwan »
I am in the middle of a water pump replacement project and having a problem with cleaning the mating surface. I used IPA but wasn't very successful. I am tempted to use sandpaper 320 or higher but would like to try something else before. Is there a proven gasket softener on the market, people used successfully, on this green paper-like gasket?
What did work for you?
januwan
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Soak the surface in some aircraft paint stripper and go ham with a plastic scraper. If you have to sand, stuff the openings with a few wet paper towels so you don't get any abrasives in the coolant passages.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
A small brass brush like a tooth brush dipped in solvent will help remove the gasket. Cleanup well afterwards.
Has thanked: 292 times
Been thanked: 765 times
I use a razor blade and no solvent. Just be careful not to gouge the surface. Would not recommend sandpaper.
Paint stripper sounds like a good idea if you can get it in and out of there cleanly.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
januwan
Post by januwan »
The brass brush and paint thinner helped a lot. It is almost clean. When I run my finger on the surface I can barely feel something. I got 800 grid sandpaper but people mentioned steel wool. What's better, safer.
Appreciate any help
januwan
Sounding good! Steel wool is safer but be sure no steel debris gets inside. Overkill but I might even tape it up quickly with painter's tape. When you're done blow it out with compressed air or shop-vac with hose on the exhaust outlet.
'06 S60 R, 197k
Geno9707
Year and Model: 2004 s40
Post by Geno9707 »
Hey how are you doing sorry to hear you are having trouble.. I always use a brass brush with medium pressure and just some parts cleaner..
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
+1 on razor blade
BMW 540i 2002
S70 Base 2000
Has thanked: 1502 times
Been thanked: 3817 times
I used a stiff box cutter blade carefully keeping it at a shallow angle to avoid gouging. I scraped more heavily with a stiff plastic trowel. I use a really thin coat of Permatex aviation gasket sealer on these, too. Not required but makes install easier
Note to 1999 RN blocks, the inner timing belt cover has to go on first before the water pump on these cars.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I also used a razor blade (carefully) to scrape off the old gasket and then a thin bead of Permatex RTV water pump gasket maker to help seal up the new water pump. It worked OK for me.
