login issues?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2865 times
Been thanked: 1332 times
Post by matthew1 »
CF cache purged, sessions table purged
Also -> Amazon link
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
The purge didn't help. As soon as I went to the main forum index I was logged in as someone else. The time is also way off.
gnalan
Post by gnalan »
Seems to be a host firewall caching issue causing the problems. Hopefully fixing that will get the site back to normal. Not sure if you've seen my latest emails or not, Matt, but I think I found the issue, but I can't fix it without ftp access (which I prefer not to have). Maybe a contributor badge, if that seems fitting?
matthew1
Site Admin
Post by matthew1 »
Any problems now?
Also -> Amazon link
gnalan
Post by gnalan »
So far it seems to be ok.
matthew1
Site Admin
Post by matthew1 »
Ok good. That's when I set CF cache to "off". That'll expire in a couple hours, then a new rule should kick in, which is
Code: Select all
don't cache https://www.matthewsvolvosite.com/forums/*
That's the real test.
You may have noticed in the last 1-2 hours some longer pageload times. That's because the cache was bypassing, making all calls hit the MVS server, html, images, css, js, etc.
Also -> Amazon link
gnalan
Post by gnalan »
matthew1 wrote: 25 Nov 2020, 16:14 You may have noticed in the last 1-2 hours some longer pageload times. That's because the cache was bypassing, making all calls hit the MVS server, html, images, css, js, etc.
A couple of times. Most of the day I've been trying to help you as much as I could, and researching what could be the main issue causing the other issues. Been a long day for me, so I can only imagine how much time you've been putting into fixing things.
matthew1
Site Admin
Post by matthew1 »
Code: Select all
Changed to
Code: Select all
don't cache https://www.matthewsvolvosite.com/forums/*.php
Running without caching is brutal. I want to cache images and miscellaneous files. Just not pages, which here at the MVS forums, have a .php extension.
Also -> Amazon link
gnalan
Post by gnalan »
matthew1 wrote: 25 Nov 2020, 16:14 Ok good. That's when I set CF cache to "off". That'll expire in a couple hours, then a new rule should kick in, which is
Code: Select all
Won't that run your bandwidth up, and site costs?
matthew1
Site Admin
Post by matthew1 »
MVS is on a Google Cloud Computing Services virtual machine (Linux - Debian) with 2 or 4 cores (I forget) and 17GB memory. Bandwidth they don't charge for in this instance.
But the server is much busier without caching, so pageload times suffer https://gtmetrix.com/reports/www.matthe ... /KddoCcY2/
In another hour or so the cache will resume, and the real test will begin.
Also -> Amazon link
