Symptoms of a dying head gasket?
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Stay positive! I feel like there's always hope (with a turbo!) especially if you have no signs of sludge in the crankcase or oil in the reservoir...
Retired:
2015 Volvo S60, T5, 85K
- Has thanked: 311 times
- Been thanked: 817 times
A head gasket failure can result in leakage in any direction between two or more of the three compartments (combustion, oil, coolant). You definitely don't need to see oil in the coolant, etc.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
How often are you adding coolant?the65dartguy1 wrote:I have a 2000 V70R that has a strange coolant issue. It keeps on bubbling the coolant out of the reservoir. I replaced the reservoir and the two hoses going to it. Also replaced the main coolant hoses at the same time.
the65dartguy1
- Year and Model: 2001 S60 2.4T
Well...test failed. Off to pull the head!
wrybread
- Has thanked: 15 times
- Been thanked: 15 times
Old thread I know, but my 2000 s70 (non turbo) has exactly the same symptoms:
- bubbling reservoir, need to add a lot of water
- changed the thermostat
- no water in the oil or exhaust or smoking exhaust
- car runs great, isn't overheating, and is running perfectly smoothly
But a friend's kit detected CO in the coolant... I'm hoping his kit is just wrong.
But if you happen to get this post, what did you see if and when you took things apart?
In the meantime I added some head gasket sealant snakeoil to my coolant and burned some tea leaves.
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
- Been thanked: 4067 times
The exhaust gas detector gives false negatives but not false positives. Time to get the head off, mill flat, new gasket
wrybread
It's still running fine. Can anyone comment on what I can expect? How long will the car be usable? It's probably heading to the great junkyard in the sky when it's done, as opposed to the mechanic shop.
wrybread
Also any clue how it happened? It's never come even close to over heating and never had a coolant leak until it started boiling with exhaust.
In CA a you can get away running straight water in moderate temperatures for a longtime, like 10-20k
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
FWIW I, and then my son drove a 98S70 N/A with that type of leak for almost three years. Just topped it up with distilled water. Added about every four days (around a cup or two a week) and never had a problem attributed to that. Ran with the needle at three o'clock, heat was strong...
Current Volvos:
- 2081 Views
Last post by lous_97_850
- 18 Replies
- 5912 Views
- 500 Views
Last post by erikv11
- 1324 Views
Last post by cn90
- 1242 Views
