Grinding noise, coolant leak, sudden death, and now won't start
Been thanked: 4068 times
Head off and valve replacement is about 20 hours of Labour. Document where you lost compression so you remember which ones to replace! I think it’s only exhaust which contact, someone confirm please.
befarrer
Year and Model: 1998 V70 AWD
Been thanked: 24 times
Post by befarrer »
Remove the spark pliugs too, then when you are turning the crank over you dont have to worry about compression. Any resistance would be valves to piston, back crank off a bit, turn cams ahead, keep going until allignment marks are alligned. Dont force anything as its likely valve to piston contact.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
