850 Hydraulic clutch issue, the return
manovlov
Has thanked: 620 times
Been thanked: 143 times
Re: 850 Hydraulic clutch issue, the return
Post by manovlov »
Hy Buddies ,
There is nothing more annoying to me that ones who look for answer, pick up some here, and never give the result. So, for my clutch : it's in progress. The car is up and the gearbox is out : it seems that the fork wasn't the right one, and apparently, there is a clip and a spring are missing. The good new is that the way I've bleeded the clutch stuff was a good one (thanks to Chuck and Volvolugnut for advices).
I will call my Volvo dealer tomorrow to order the parts.
A fork, a spring, a pin and a clip : do I forget something ?
Manov
Has thanked: 1836 times
Been thanked: 1709 times
I did suggest here may be a problem with the fork!! But I would not have thought the wrong one was fitted or parts missing. It was the only way I could see the slave cylinder rod over extending. Hopefully, this is now the issue getting fixed for the last time.
manovlov
Post by manovlov »
scot850 wrote: 03 Dec 2020, 10:44 I did suggest here may be a problem with the fork!! But I would not have thought the wrong one was fitted or parts missing. It was the only way I could see the slave cylinder rod over extending. Hopefully, this is now the issue getting fixed for the last time.
Yep ! Does someone can guide me to list the parts I need ?
I'm sure you did before, but can you send me your Vin# and I will pull out the Vida laptop tonight and see if I can find the part numbers you need.
manovlov
Post by manovlov »
Ok hold on... I've sended it to you already, Neil, have a look in your mailbox.
Thanks for your help...
manovlov
Post by manovlov »
Sorry, I sen it again. Apologize
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
So, someone has been messing around in there before you, if the fork is incorrect.
The missing bushing would've caused the over-extension of the slave cylinder, but it sounds like someone put it back together wrong in the first place.
