Groaning/Whine from front right side of engine
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
Hi Everyone,
So ive noticed that the 98 v70 has recently developed a mid tone mechanical whine that seems to be tied to rpm. At first i thought it was low power steering fluid, however i filled it and it still persists. This is not an urgent issue as i am about to go through exams, however i wanted to keep a log of this in case it escalates.
As of right now the following has been checked and tested:
Power steering fluid - filled to spec
Oil- middle of the specification on the dipstick, last oil change was 5000 km
Transmission fluid - Brownish darker, last drain and fill was 24k km ago so it is on the list to change, transmission does not jolt, jerk, or make odd sounds
Issue persists in neutral, drive, does not seem to go away with speed. I will see if i can upload a recording at some point.
2008 S60 2.5T Auto (Sold)
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
things to check, alternator/bearings, serpentine belt idler/tensioner, water pump, timing belt idler/tensioner
Get a mechanics stethoscope to pinpoint. If it's the water pump or timing belt items, it becomes critical.
Current Volvos:
yanga001
Post by yanga001 »
Forgot to mention, timing belt done 3000 km ago along with water pump by a master independent. He inspected the rest of the timing area when he did the work.
Ill check the serpentine and alternator.
hipcheck
Year and Model: 1997 850
Has thanked: 6 times
Been thanked: 7 times
Post by hipcheck »
yanga001 wrote: 03 Dec 2020, 19:48 Forgot to mention, timing belt done 3000 km ago along with water pump by a master independent. He inspected the rest of the timing area when he did the work.
That’s good news!
Start hunting down the serpentine belts and it’s associated hardware.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
I had (have, I've yet to fix it) a similar issue. A mid-tone whine that was tied to revs, but mine only existed when the engine was cold. As it warmed up the noise slowly faded. In my case it was a bad serpentine idler pulley and bad tensioner pulley. Which of the two was causing the noise I can't say, though the idler pulley was more deteriorated.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Another possible source of the groaning sound can be the oil thermostat near the oil filter. It makes a strange moaning/whistling noise when the engine oil is cold and goes away when the oil is fully warmed up.
Has thanked: 1611 times
Been thanked: 4072 times
Whenever I pick up Matt in the T5 I get a whining but I’ve figured out it comes from the passenger seat
Cookeh
Post by Cookeh »
jreed wrote: 06 Dec 2020, 06:18 Another possible source of the groaning sound can be the oil thermostat near the oil filter. It makes a strange moaning/whistling noise when the engine oil is cold and goes away when the oil is fully warmed up.
Now that is very interesting, I have not heard of this before. Are there any threads discussing it? To be honest, I didn't even know these had oil thermostats.
jreed
Post by jreed »
I would refer to this thread from 2012, with the description by Ozark Lee
https://www.matthewsvolvosite.com/forum ... 22#p261822
FLXC90
Post by FLXC90 »
Cookeh wrote: 06 Dec 2020, 10:47
The OP does not, as his car is N/A. He needs to stick to the spinny parts outside the timing cover.
Current Volvos:
