How important are trailing arm links (aka transverse arm bushings)?
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
Is it urgent that I replace the trailing arm (aka transverse arm) link bushings if they look cracked? My newly acquired 2000 V70 needs a full suspension refresh yet this seems like the hardest part with the least pay off. How do these bushings look to you?
FireFox31
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
If it feels like rear wags when changing lane or a sensation of rear skidding, then you need to service the trailing arm components. It is not safe for wet weather driving on freeway.
This may help a little https://www.matthewsvolvosite.com/forum ... =1&t=65148
my98s70glt
- Year and Model: 99 V70R, 07 V70 2.5T
- Has thanked: 11 times
- Been thanked: 5 times
I changed both of mine and it Immediately tightened up the rear-end. I would say it’s worth it and not that difficult of a job. I used the Volvo tool and a little heat. I learned later from others that more heat, essentially melt the rubber inside the arm, would’ve saved me a bunch of time.
Current:
1999 V70R: Signal Red/Charcoal || Snabb RIP Kit || Snabb Air Intake || Simons Axleback Dual Exhaust
2007 V70 2.5T: Snabb Fresh Air Pipe || BC Racing Coilovers
Previous: 1998 S70 GLT, 2006 V70 2.5T, 2011 C70 T5, 2012 S60 T5, 2000 S70 GLT/SE
- Has thanked: 1611 times
- Been thanked: 4071 times
Get the back end up and see how much movement is in them when you pry with a tire iron
I would say you have a couple of years on them left.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Is it critical for this moment? If it were me, no. Should you get them done in the future? I would. Would I prioritize it over a pizza this month? Nope.
2023 Lexus RZ450e -66k
- Has thanked: 2207 times
I have seen worse. Also check the other end. There are aluminum mounting blocks. I have seen those crack in areas with lots of rust issues.
- 1404 Views
- 2983 Views
Last post by 800artfreed
- 448 Views
Last post by alschnertz
- 1009 Views
Last post by bkw1962
- 11 Replies
- 10616 Views
Last post by BlackBart
