Anyone know how to get one of these springy contact FM transmitters to get power in my 12v plug?
The cig lighter works....
Volvo 850 12v Outlet
- Has thanked: 2199 times
I have issues with more modern stuff plugged in in the cigarette lighter on P80's. The lighter socket is very low current and can't power much out of it.
I'm hoping others will chime in with solutions for this issue.
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
I run on mine fine the car tire pump. I wouldnt say it being a low current side. I would check connections with and without a load and is there corrosion too much in your outlet. It should be electrically capable even blow your fuse. I dont remember fuse size top of my head sorry just.
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Its just a compatibility issue. Weirdly different products have different widths and heights so not all fit properly and not all will make sufficient contact to compress the metal switches. I found Anker branded usb charges don't fit, but Aukey ones are.
You also need to consider the size and shape of the item you're trying to plug in. As you know the plug is recessed on an angle, so if the item is too large or has a sufficiently curved base it can stop the item from being fully seated, and hence grounded.
- RickHaleParker
- Been thanked: 978 times
Remove the Cigarette outlet and replace it with a Accessory outlet. There are two different standards.
Active
Past
Past
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
This is what I've done on both of our cars.RickHaleParker wrote: 11 Dec 2020, 07:15 Remove the Cigarette outlet and replace it with a Accessory outlet. There are two different standards.
Dave in Maine
- Year and Model: 2009 S60 2.5T
- Been thanked: 3 times
1. Get after all the contact surfaces with a pencil eraser until you see bright metal. I see rust in your pictures, especially around the center rivet, and that tells me all the contacts have a coating of nonconductive oxide, much of which you probably cannot see.
2. My 850 used a 20A fuse for the lighter. Try a 20A.
3. When you insert the plug into the outlet, try gently twisting it in the socket until you get power.
1996 850 Turbo Gold Edition, 7 years' reliable service and >220k mi, sadly now gone
2009 S60 2.5T, sent away after taking me down Via Dolorosa. Happy to be rid of it.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
+1 for cleaning and/or a little wiggle jiggle.Dave in Maine wrote: 15 Dec 2020, 15:34 1. Get after all the contact surfaces with a pencil eraser until you see bright metal. I see rust in your pictures, especially around the center rivet, and that tells me all the contacts have a coating of nonconductive oxide, much of which you probably cannot see.
And that FM modulator draws nowhere near
10 amps. A larger fuse wouldn’t be a fix.
IIRC, the rated fuse for the cigarette lighter
( position 30 ) is 10 amps. A higher fuse value
is not a good idea - Things can get melty...
- RickHaleParker
12V outlets can develop leakage currents that will push the current over the limit of the fuse when loaded. Over time heat damages the insulators. If the outlet is defective and it is un-switched it can be a source of phantom currents that drain the battery overnight.
The fuse is there to protect the wiring also. Do not put a higher rated fuse in it. Find the cause of the excess current and correct it.
Excess current in wiring is #3 in the list of fire causes. If you want to set your 850 on fire, take it out in a field ,dose it with Diesel fuel then toss the match. Don't be doing it on the public roads where the rest of us are. Do not use Petrol unless you trying to be a martyr.
Active
Past
Past
You can also do that by not checking your B+ cable in the main fuse box to make sure it is not burnt and shorting out.
- 24 Replies
- 12257 Views
Last post by mikkowus
- 4080 Views
Last post by Oh4FoxSake
- 2913 Views
Last post by 93SCMax
- 576 Views
Last post by rocky_mtn_man
- 777 Views
