Please help I am having a senior moment. BTW I am a senior
P80 heater core screw , core to pipe 986200
januwan
- Year and Model: 97 850 NA 209 K
- Has thanked: 7 times
- Been thanked: 3 times
I just replaced my original heater core. Four thread forming screws (I think this is the correct name) are installed but I am not sure if the horizontal screw between the pipes is the same thread forming screw or is it a machine screw with a finer thread. I do have one "extra" t25 screw with finer thread.
januwan
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
I believe the one you refer to is longer and has a different thread pattern from the others. It has to be snugged down nicely, so you'll pretty much need the identical screw. Someone else might chime in. I think I have a couple somewhere. Did you lose yours?
januwan
Thanks rguzz. When I was pulling the old core, this screw landed on the carper but I thought the screw in question was still on the core. I was looking for the place it came out but I couldn't find any. I was under the impression (I don't know why) that all screws have the same thread. I spent some time looking for the fifth screw with the same thread. I finally checked Robert's video and realized the horizontal screw between the pipes has a different thread.
Everything is already assembled and is working fine.
januwan
- Been thanked: 4064 times
It is a T25 head machine screw and is different from the screws that hold in the core frame
Part 986200 M5 x 16 mm size
It is hard to find internet Volvo diagram because it hides in the body > air distributor tab, not in the climate or cooling group area
Volvo Obscura..a 1968 P1800 uses the same screw to hold the fuel pump in.
- 581 Views
Last post by erikv11
- 3586 Views
Last post by wizechatmgr
- 1380 Views
- 11 Replies
- 9787 Views
- 5111 Views
Last post by darrylrobert
