sheared subframe bolt '96 850
jlp920
Year and Model: '96 850, '95 940
Has thanked: 5 times
Post by jlp920 »
Hey folks.
I'm doing the steering rack, among other things, on my '96 850, 20v non-turbo.
The driver's side subframe bolt (rear position, roughly under the driver's floorboards) sheared on me, while the other rear one came out
just fine. There is a red protuberance into which this bolt was threaded. I'm prepared to dig into the floor of the drivers side to try to access the other end of this thing, not sure what I'm about to find. It was strange because it started coming out fine then gradually bound up until finally I sheared it with a breaker bar. At least I can get the rack out now :roll:
So....anyone come up against this kind of thing?
-Jesse
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
That is a locating nub for the subframe. There are two on that side (1 front and rear). Helps keep the SF square under the frame.
That's gonna be a bear to get removed, I think.
Has thanked: 1500 times
Been thanked: 3812 times
Get a nice new sharp bit , center punch and drill out. You might need 2 or even three drill bits to release that depending on how well you control drill feed.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
When I get a bolt turning and it gets tight, that is the signal to stop and rethink what I am doing. Boldly going forth with more breaker bar torque usually will lead to broken bolts. Soak it with oil, reverse direction, add some heat, but don't just keep applying more torque. That is how I have broken many bolts.
But you knew all that.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Shorten the bolt a bit with a benchgrinder or similar. Looks like there are plenty of thread on there. Maybe not the best solution from a security pov though...
BMW 540i 2002
S70 Base 2000
jlp920
Post by jlp920 »
abscate wrote: 15 Dec 2020, 19:19 Get a nice new sharp bit , center punch and drill out. You might need 2 or even three drill bits to release that depending on how well you control drill feed.
I like that option. Right up through the nub?
Any point in attempting to access the other side?
jlp920
Post by jlp920 »
Chuck W wrote: 15 Dec 2020, 18:54 That is a locating nub for the subframe. There are two on that side (1 front and rear). Helps keep the SF square under the frame.
Thanks for identifying it. I ran into a bit more than I bargained for.
Any further help on my approach is welcomed. The manuals don't have a lot to say at this point.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Also, buy and use a left-handed bit. The bit may grab and extract the screw.
http://www.ultimatehandyman.co.uk/how-t ... hand-drill
jlp920
Post by jlp920 »
Yeah, I am well aware that I screwed the pooch here. Believe me, I know. The question is, do I now have a pile of scrap or can I work through this?
Pretty obvious I will need to drop the entire subframe in order to get at that bolt with a drill bit. Thanks again for your feedback, it's a very disappointing situation for me. That said, if there's a path forward I need to take it.
You will get through it, it’s been done amd conquered before. I think Kally felt with one of these on her 1998 and she got it done in her driveway in winter. I’m no Spring Chicken, and the Creator built her before me.
Heat it for a couple of cycles to get the metals talking to each other, spread the Holy Water of PB Blaster liberally.
I don’t think you can get to the top of these without major surgery.
Gauntlet thrown.
Dropping subframe isn’t too bad. Are you near me in NE? I can loan the engine carrier and save you fabbing one. I do need it back to a steering rack but time isn’t critical right now
